U Joint Size.
by Trailmonkey - 11/19/20 04:50 PM
by Trailmonkey - 11/17/20 12:33 AM
F/S 1988 Mighty Max 4wd with Starion Power
by rxinhed - 11/14/20 05:04 AM
Positive Camber ? Why ?
by Trailmonkey - 11/13/20 05:57 PM
Windshield removal/install ?
by rxinhed - 10/31/20 11:33 PM
U Joint Size.
by Trailmonkey - 11/11/20 04:29 PM
0 registered members (), 117 guests, and 6 spiders.
Topics138,151
Posts1,080,858
Members15,113
1989 Montero reinstall the distributor #1079401 10/28/15 03:47 AM
L
losduarte Offline OP
Hello all. My rebuild nightmare is almost done. However, I am sure I incorrectly installed my distributor, because it won't start.
I will follow the following steps as well:
http://www.4x4wire.com/forums/ubbthreads.php/ubb/showflat/Number/756722/site_id/1#import
Thank you.
Re: 1989 Montero reinstall the distributor [Re: losduarte] #1079418 11/02/15 12:44 PM
JAVYPRO Offline
Set the engine to TDC, check the marks of the cams and the damper and align the two marks of the dist and it should fire. If you align the mark of the damper but the cams are not aligned then you are on exhaust, turn the engine one more time.
Javy
Re: 1989 Montero reinstall the distributor [Re: losduarte] #1079438 11/06/15 03:53 AM
tdf46 Offline
An easily made mistake:
When you are sure that the cam timing is correct and it won't start the distributor install is a likely suspect.
Recently, I forgot that the distributor cap design is a little unique in that the initial rotor postion does not line up with the wire post for #1 cylinder but instead points at the approx. center of the fire wall. This is due to the factory design of the distributor cap. This is described in the FSM.
Then set basic timing per FSM procedures.
Re: 1989 Montero reinstall the distributor [Re: losduarte] #1079442 11/07/15 04:10 AM
fasteddy Offline
IIRC, there is a mark on the dizzy shaft housing, and two two drill marks on the shaft. One mark is the "to install" mark, and the other is the "installed" mark, since the shaft turns as it's stabbed. Set the shaft on the "to install" mark and center the adj slot over the stud, and stab it, crank/cam marks aligned as described.
And, no, I didn't die. Living in the woods with no internet. Y'all come...
Re: 1989 Montero reinstall the distributor [Re: losduarte] #1079443 11/07/15 01:04 PM
H
haztoys Offline
Nice to have you here I hope all is good Fasteddy
Re: 1989 Montero reinstall the distributor [Re: losduarte] #1079447 11/08/15 02:33 PM
Mudraider Offline
Yes, great to see you on here again.
Re: 1989 Montero reinstall the distributor [Re: losduarte] #1079451 11/08/15 08:50 PM
JAVYPRO Offline
Eddy, so glad to hear back from you. I as well have been a little lost but I am so gad to say hi.
Javy
Re: 1989 Montero reinstall the distributor [Re: tdf46] #1079453 11/09/15 06:59 AM
L
Aha, that would one of the things I am doing wrong. You are right the rotor does not align with the wire post for cylinder #1. I will try this. Thank you.
PHP: 7.2.34 Page Time: 0.014s Queries: 15 (0.004s) Memory: 2.8597 MB (Peak: 3.1636 MB) Data Comp: Off Server Time: 2020-11-23 20:00:13 UTC
