by Bigshankhank. 01/16/19 02:43 PM
My first Raider
by ATTILA. 01/13/19 01:29 PM
by tdf46. 01/12/19 12:15 AM
by tdf46. 01/12/19 12:12 AM
Introduction & New Raider
by Mudraider. 01/11/19 04:11 AM
2nd Gen Front Lincoln Locker.
by RockDoc. 01/12/19 10:31 PM
My first Raider
by Flicky8. 01/12/19 03:28 AM
by tdf46. 01/09/19 03:56 AM
0 registered members (), 105 guests, and 6 spiders.
Topics137,963
Posts1,079,872
Members14,872
Urgent: crankshaft bolt came loose #1079865
01/19/16 05:52 PM
01/19/16 05:52 PM
JAVYPRO  Offline OP
Buford, GA USA
Hey guys,
I finished the heads on the 1990 LWB and the next day this.
My wife was driving her 2001 Gen III and at about 1/2 mile from home she noticed a strange noise, she knows her truck like no other, and drove it home right away. When she called me I was sure it was the idler pulley as it has been making a vague chirp, so when I got home from the office I pulled the Montero in the garage but the noise was really bad as if the bearing had given up completely.
Under close inspection I noticed the belt at the crankshaft pulley was out of alignment, I checked the bolt and it was hand tight shocked . This is a new bolt that was installed when my mechanic did the timing belt 8 months ago +/-.
This morning I took everything apart and indeed the bolt was loose and the crankshaft was loose as well, it had sheared off the little round key and scrape a bit of the plastic and the back part of the pulley.
Noting seems to be damaged other that the scraping so I need to remove the round key and use a new bolt. Should I use thread locker or oil as per the FSM?
I am trying to post some pics, here is the link to the pics:
GEN III crankshaft pulley pics
Thanks,
Javy
Re: Urgent: crankshaft bolt came loose [Re: JAVYPRO] #1079866
01/19/16 06:11 PM
01/19/16 06:11 PM
JAVYPRO  Offline OP
Buford, GA USA
Looking for the parts online, I am afraid that round key comes with the timing sprocket. I do not have the tools to remove the timing sprocket. Now, can the key be removed from the new sprocket?
Javy
Re: Urgent: crankshaft bolt came loose [Re: JAVYPRO] #1079884
01/22/16 08:39 PM
01/22/16 08:39 PM
JAVYPRO  Offline OP
Buford, GA USA
OK, No damage to the timing sprocket. Tomorrow will remove the roll pin , will install a new pulley, new roll pin and a new bolt with thread locker opposite to plain motor oil as per the FSM.
Thanks,
Javy
Re: Urgent: crankshaft bolt came loose [Re: JAVYPRO] #1079926
02/01/16 08:21 AM
02/01/16 08:21 AM
Maciek  Offline
Seattle, WA
eep, well i guess the compression pin did it's job. how'd the repair go?
i just stripped one of my hub bolts repacking the front wheel bearings, then the bolt i welded in to it just sheared. guess the left one will have to wait a little longer till i motivate to drill it out and try a better bolt than a rusty old one dug up from he bolt bin smirk
Re: Urgent: crankshaft bolt came loose [Re: JAVYPRO] #1080187
03/27/16 01:41 PM
03/27/16 01:41 PM
JAVYPRO  Offline OP
Buford, GA USA
It worked excellent. It happen that the SOB mechanic did not use the new bolt I had for the damper, he used the same bolt that was there.
Bought a new damper ($197)+ bolt ($7) some blue thread locker and fabricated my own adapter to hold the damper while torque was applied.
It worked like a charm, the Montero is back on the road as if nothing happened.
At the end, the issue was caused by human laziness.
Javy
Re: Urgent: crankshaft bolt came loose [Re: JAVYPRO] #1080189
03/28/16 12:34 AM
03/28/16 12:34 AM
Mudraider  Offline
Orange Park, FL
Sorry to hear that dude.
Re: Urgent: crankshaft bolt came loose [Re: JAVYPRO] #1080294
04/09/16 07:34 AM
04/09/16 07:34 AM
Ian Sharpe  Offline
Braidwood NSW, Australia
happened to me on my Gen 2.5. Bolt broke off & i had to drill it out with a hardened bit. Buggered up the hole a bit, so I eventually re tapped the hole to take a m16 fine x 50 mm bolt. Plus lock tighted it on It aint coming loose again in a urry.
97 Exceed, 3.5l SOHC auto, 4.90 gears, ARB front locker,rear Harrop E-Locker, Magnum winch, dual transfer cases also 2008 NS swb Pajero, front bar & winch
Page Time: 0.011s Queries: 15 (0.004s) Memory: 1.0245 MB (Peak: 1.1365 MB) Zlib disabled. Server Time: 2019-01-16 17:09:07 UTC
