99
Posts1,080,940
4G64 DOHC with custom AX5 trans 4 sale.
#1080482
05/02/16 12:20 AM
Hi guys so the whole setup is up for sale. This engine will fit any mitsu trans and starion/conquest (wide block). I have decided to go green sticker on my Montero and will install a 4BT. 4200$obo
here is the build threads,
http://www.4x4wire.com/forums/ubbthreads.php/ubb/showflat/Number/1047252/Searchpage/1/Main/132419/Words/4g64+vs+v6/Search/true/Re:_4Cyl_turbo_Vs_V6_3.0?.html#Post1047252
http://www.4x4wire.com/forums/ubbthreads.php/ubb/showflat/Number/1065805/Searchpage/1/Main/134736/Words/4g64+vs+v6/Search/true/Re:_Mixtubishi__trans_has_been.html#Post1065805
Re: 4G64 DOHC with custom AX5 trans 4 sale.
[Re: 87monty]
#1080484
05/02/16 01:14 AM
[Re: 87monty]
#1080491
05/02/16 03:07 PM
Hello, I joined today and was looking on the site to get info about the Pajero as a jdm turbo diesel Pajero is for sale in the states.
Anyway, while looking I saw you had a built 4g64t and wondered if you be willing to just part with the engine as I don't know if it would work on my car.
I have a 2000 2.4 galant but my issue is what do about the fact that your engine seems to be rotated 180. I looked around and have not been able to see if it is possible to just flip the bolt ons or not.
Please let me know if I can just get the engine. And if it would be possible to flip the engine or if I would need to disassemble and rebuild flipped.
[Re: 87monty]
#1080495
05/02/16 06:44 PM
Welcome to 4x4Wire TrailTalk forums.
While this posting is specific to additional information about the part for sale, there are other tech sections dealing with Mitsubishi where you may find additional information..
Please check in and introduce yourself.
[Re: 87monty]
#1080512
05/03/16 05:28 AM
Hi begood12, and welcome to the wire. I can check into your question and let you know. The only thing I'm not sure about is theres a wide block and narrow block 2.4L If the Galant has the wide block transmission then this would be a bolt in. I would be up for selling just the motor,ecu,software and harness no problem. I will get back to you and feel free to ask in the mitsubishi tech section, this is a great place with very Knowledgeable People.
[Re: 87monty]
#1080559
05/05/16 02:43 PM
Thank you very much I will see if the auto trans is a wide no ok or not. I also know I would need to beef up my trans. But the car is old and I love the platform so I would likely rebuild trans
[Re: 87monty]
#1080597
05/07/16 02:54 PM
Bgood12, Galant is narrow block. And as you noted, the engine is reversed in the 2000 Galant, so the head wouldn't work either. If you want some 4G64 advice, run over to the yahoo group and ask some questions. https://groups.yahoo.com/neo/groups/4g64/info
Curt Shambeau 87 Mitsubishi Montero SWB (Turbo G64b wideblock conversion soon)
[Re: Struc]
#1080613
05/08/16 04:23 AM
[Re: 87monty]
#1080641
05/12/16 12:00 AM
OK so I am at the point were I will except any reasonable offer for either the trans or motor. I do not want them just sitting around out of the Montero. Please let me know as I plan to pull them in a few weeks. I did get a shipping quote for 400$ for shipping from California to Ontario Canada.
[Re: 87monty]
#1080655
05/13/16 03:20 AM
Sorry for the late reply. Thanks though, I wish it would have worked. Good luck.
