Replacement MAF unit .. Gen1
Gen1 cigarette lighter port.
by polar - 02/16/21 03:03 AM
0 registered members (), 100 guests, and 6 spiders.
Topics138,179
Posts1,081,008
Page 1 of 3 1 2 3
Died running, now no spark #1080561 05/05/16 08:18 PM
JAVYPRO Offline OP
I was on my way to work this morning on my 1990 LWB and 1/4 mile from home the engine died. Brought it home, cranked it and nothing, it has fuel as I can hear the fuel pump running but it shows no spark.
I tested the coil per the FSM. Tested the primary coil resistance (from + to Hight voltage terminal the standard value calls for .72-.88 ohms I get .9ohms.
Then tested the secondary coil resistance. Standard value calls for 10.3-13.9 Kohms, I am getting 11.
Also tested the power transistor also per the FSM and it tested fine. Still went to the auto parts and got a new one and still no spark (they were nice to accept it back).
So, what now? the ECU is freshly rebuilt. What else could it be?
I cannot enjoy driving this thing.
Javy
Re: Died running, now no spark [Re: JAVYPRO] #1080564 05/05/16 08:26 PM
TOASTY Offline
Optical sensor in the dizzy is your next suspect. If you have a friend with an old DSM datalogger you can test while cranking to see what the tach is sensing for a signal (the stock gauge isn't sensitive enough to diag). If it's all over the place or not registering, there is your fault.
1999 Montero Blizzard package
1991 Montero RS
Re: Died running, now no spark [Re: JAVYPRO] #1080566 05/05/16 08:36 PM
JAVYPRO Offline OP
Unfortunately I have no access to a data logger.
Javy
Re: Died running, now no spark [Re: JAVYPRO] #1080567 05/05/16 08:43 PM
fasteddy Offline
MarkG had one.
Re: Died running, now no spark [Re: JAVYPRO] #1080569 05/05/16 09:27 PM
JAVYPRO Offline OP
If it is the optical sensor the only way to replace it is by replacing the distributor unit, right?
Javy
Re: Died running, now no spark [Re: JAVYPRO] #1080572 05/05/16 11:46 PM
PajEvo Offline
A friend (or junkyard) with a distributor to swap in would narrow it down for sure. I have evoscan and the cable here which can read MUT language but the turnaround time would be long...
Re: Died running, now no spark [Re: JAVYPRO] #1080576 05/06/16 10:45 AM
P
pcc Offline
Did you check for actual primary voltage? I believe you can also connect a 12v test light to the primary and while cranking engine watch it blink as primary is switched off and on. If not blinking then it'll be the primary switch. I think the switch was the power transistor with signal from ECU.
Re: Died running, now no spark [Re: JAVYPRO] #1080581 05/06/16 01:46 PM
BottomFeeder Offline
I picking up a 91 which had the ECU rebuilt. ECU took a crap again. Owner is tired of dealing with it.
My point is, see if you can borrow a ECU to rule out this theory.
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: Died running, now no spark [Re: JAVYPRO] #1080583 05/06/16 02:01 PM
H
haztoys Offline
Never do a reman ECU ... The ECU is wounded and they just fix what they see as bad then the ECU just keeps dying on some other part down the line in the ECU ... Get a good used ECU ..
I bet its the igniter "plug" at the igniter .. Not the igniter but the plug ...
Captain Gear Box
Hazardous Toys inc ..
Re: Died running, now no spark [Re: haztoys] #1080586 05/06/16 04:39 PM
P
pcc Offline
I must say my repaired ECU, done by avproecm.com, has been great. Repaired several years ago and no problems - great price and turnaround. Unfortunately the web address is not active any more. But there may be another one out there worth a try.
Page 1 of 3 1 2 3
PHP: 7.2.34 Page Time: 0.015s Queries: 16 (0.004s) Memory: 2.8901 MB (Peak: 3.1635 MB) Data Comp: Off Server Time: 2021-03-01 07:40:53 UTC
