Search 4x4Wire
Fuel filter problem
by Rocker. 01/23/18 06:31 AM
Carb Question
by rxinhed. 01/21/18 06:06 PM
correct idle RPM for 91 Montero
by rxinhed. 01/21/18 06:02 PM
CA: 89 SWB V6 Need Washer Fluid Container
by rxinhed. 01/21/18 06:01 PM
Stalling 1989 Raider
by cheesegrater. 01/21/18 12:58 PM
relay module ID - need help
by dfreem01. 01/21/18 04:27 AM
lugs for aftermarket alloy wheels?
by rxinhed. 01/21/18 12:36 AM
by jeffmort. 01/20/18 05:32 PM
ECU code reading - first timer rookie
by jeffmort. 01/20/18 08:19 AM
by cheesegrater. 01/19/18 01:32 PM
by jeffmort. 01/19/18 06:51 AM
Ranger .22 Pump-Action Rifle?
by lupacexi. 01/19/18 04:10 AM
CanCooker Recipe for January 2018
by 4x4Wire. 01/17/18 09:50 PM
My '88
4x4Wire YJ
0 registered members (), 126 guests, and 6 spiders.
Topics137,740
Posts1,079,181
Members14,725
Rate This Thread
#1101525 - 06/16/16 06:12 AM 90 Montero Seems starved for gas
Dartmouthbrian  Offline
Seattle WA
Any ideas? Starts, but seems starved for gas, surges. Definitely not drivable.
Things done: Checked the throttle body, Checked the ECU, Tried a new ECU, New fuel pump...
Thoughts??
91 Montero RS
90 Montero base
#1101528 - 06/16/16 06:10 PM Re: 90 Montero Seems starved for gas [Re: Dartmouthbrian]
DJPASS7  Offline
Chico, CA
Seems a lot like the infamous idle air control valve (IAC). Here is a link on how to clean it. http://www.4x4wire.com/mitsubishi/tech/throttle_body/
1989 Montero LS LWB
Rear LSD, KYB's, 3.0L, Lockup A/T, 2" BL, T-Bar Crank, 33" MTZ's, Full Length Roof Rack, 9k Winch with custom bumper, Rock Sliderz
#1101531 - 06/16/16 08:10 PM Re: 90 Montero Seems starved for gas [Re: Dartmouthbrian]
Seattle WA
Thanks DJPASS7. Definitely not the issue on mine. I should have been more clear on the throttle body piece I mentioned above. That has been done. Still no bueno.
91 Montero RS
90 Montero base
#1101564 - 06/21/16 05:53 AM Re: 90 Montero Seems starved for gas [Re: Dartmouthbrian]
Seattle WA
Man... I could sure use some advice. I have searched HIGH and low... On this forum, on other forums.. Even on other car forums.
Basically what I traced down to the MAF sensor (or so I thought). I was able to start the truck and keep it running if I had the MAF Sensor unplugged, but if I touched the gas she would dies. Got another MAF Sensor off a truck that had been running fine before being wrecked. Plugged in and the Montero started and ran, but same issue, touch the gas and it dies.
I have been through the TPS, IAC, ECU, MFI Relay, Fuel Pump, MAF Sensor, cleaned the throttle body... Im at my wits end here.
Any ideas??
91 Montero RS
90 Montero base
#1101567 - 06/21/16 09:52 AM Re: 90 Montero Seems starved for gas [Re: Dartmouthbrian]
cheesegrater  Offline
Franklin IN
Have you checked for clogged fuel filter or injectors?
#1101568 - 06/21/16 10:21 AM Re: 90 Montero Seems starved for gas [Re: Dartmouthbrian]
pcc  Offline
South East U.S.A.
Can you very slowly depress the gas pedal and get it to rpm higher? Is the idle OK? I would have thought TPS as that's the sensor that tells the computer to give it a shot of gas when depressing gas pedal.
Maybe try using starter fluid to give it a shot as you open the throttle, see if that helps. If so I'd still look to TPS.
#1101572 - 06/24/16 06:45 AM Re: 90 Montero Seems starved for gas [Re: Dartmouthbrian]
Seattle WA
Cheesegrater: yes, actually changed the fuel filter too.
pcc: I'll try that. Thanks for the advice. Maybe I'll try another TPS.
I am going to check a few more things. I'll report back. This one is baffling. I'll make sure no matter what to document what I find in case someone else runs into this problem at some point.
91 Montero RS
90 Montero base
#1101576 - 06/24/16 02:27 PM Re: 90 Montero Seems starved for gas [Re: Dartmouthbrian]
4x4Wire  Offline
Lakeside, CA ***
Did you test fuel pressure? You said you replaced filter and pump. But, did you verify the pressure? Your surging can come from uneven fuel flow. And, fuel systems are pressurized to the point that a bad gas cap not sealing can cause performance issues.
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.010s Queries: 15 (0.004s) Memory: 0.8378 MB (Peak: 0.9623 MB) Zlib disabled. Server Time: 2018-01-23 09:28:58 UTC
