114
Topics138,177
Posts1,081,002
97 montero sr Any one added a fan or two?
#1101584
06/25/16 09:25 PM
Looking under the hood of my montero there are alot of coolers. a Transmission cooler, i think an oil cooler, and a fan that hooks up to what i think is my a/c.
Has anyone found it beneficial to add a fan to the transmission or oil cooler? How about another fan for the A/c? Looks like it would fit.
I did have the a/t light come on at the exact moment i summited a rather vertical hill. I think its time for a flush but a cooler fan is attractive as well.
97 Montero SR: 2in body lift. 33" KM2
Re: 97 montero sr Any one added a fan or two?
[Re: MMeadows]
#1101593
06/26/16 03:32 PM
using our search function nothing comes up when i search "Montero transmission cooler fan"
Im guessing it has not be attempted alot on this form, ill post my results for future searchers
[Re: MMeadows]
#1101595
06/26/16 04:13 PM
One of the many common fan replacement methods has been to use either a Volvo or Ford Taurus fan, but only for the primary cooling.
When folks start down this road of 'potential' modification, we stop and ask them why? The 'why' is important and can save hours of time and also wastes of $$ during the evaluation.
so...why?
[Re: rxinhed]
#1101598
06/26/16 06:00 PM
my AT light came on as i was off roading. It happened WHen I went up a very steep hill that took a solid 5 min or so.
[Re: MMeadows]
#1101629
06/29/16 07:59 PM
my AT light came on as i was off roading. It happened WHen I went up a very steep hill that took a solid 5 min or so. That would be the Jeep AW3 transmission if that's a '97, correct? Edward
'97 Montero Sport LS 5-Speed 3.5L conversion SAS Dana 44s & ARBs, 35" Yoko Geolandar M/Ts NP231 B4R doubler/Terra Low231/RP 5.38 229:1 '99 Montero Sport Limited 4WD SAS 3-link project '03 Montero Sport Limited AWD '97 Montero Sport LS 5-Speed 4WD
[Re: MMeadows]
#1101636
06/30/16 01:12 AM
Still the same old Aisin Warner tranny. Makes a lot of heat with the converter unlocked. You pull a steep grade with lots of slip, the converter really heats the fluid. You might gain some marginal improvement in at temp with rad airfow, but I'd let it go.
[Re: MMeadows]
#1101637
06/30/16 01:50 AM
[Re: MMeadows]
#1101651
06/30/16 07:36 PM
my AT light came on as i was off roading. It happened WHen I went up a very steep hill that took a solid 5 min or so. How good is the radiator? This may be a symptom of a radiator that needs maintenance (flushing needed, rodded, re-cored or even replaced).
[Re: fasteddy]
#1101654
06/30/16 07:55 PM
Still the same old Aisin Warner tranny. Makes a lot of heat with the converter unlocked. You pull a steep grade with lots of slip, the converter really heats the fluid. You might gain some marginal improvement in at temp with rad airfow, but I'd let it go. That's what I thought. Yea, the OP would probably be better off looking through the Cherokee threads. Lots of info on there about transmission coolers. What I got off those threads was to pull the transmission out of the radiator and install a standalone cooler. About half put one in front of the condenser/radiator. The guys running 37/38+ tires install a separate cooler with its own fan and put it where it'll fit. Mitsu never did a deep sump pan for the AW3, but there is a company out there that does sell one. The dipstick is on the PS side though. For whatever its worth. General opinion seemed to be leaning towards that not being worth the effort - what was really needed was a separate cooler and/or fan. I'm not a huge fan of the in-radiator cooler. It is nowhere near as efficient as a properly installed stand-alone unit. Edward
[Re: off-roader]
#1101655
06/30/16 07:55 PM
my AT light came on as i was off roading. It happened WHen I went up a very steep hill that took a solid 5 min or so. How good is the radiator? This may be a symptom of a radiator that needs maintenance (flushing needed, rodded, re-cored or even replaced). That's what I was thinking, too. Edward
