87 Gen1 Rebuild in Kansas
by Tuxedo_Ranch - 06/04/20 06:11 PM
97 4Runner too Old to Keep?
by brink - 06/03/20 06:10 PM
Hankook or Nitto?
by Jx4x4 - 06/02/20 04:14 AM
by brink - 06/01/20 09:54 PM
'95 Montero 3.5L Coil Blowing
Hankook or Nitto?
2003 montero sport worth it?
by BC4x4 - 05/23/20 11:34 PM
0 registered members (), 111 guests, and 5 spiders.
Topics138,117
Posts1,080,628
Members15,064
Troubleshooting fuel pump (Gen2.5 Montero) #1101628 06/29/16 05:43 PM
Mudpie Offline OP
I bought a '99 Montero, not running. It's a long story (isn't it always?), but I'm thinking it's a fuel pump. I'm going through the process to check, but I've never worked on a Montero, and I'm having some trouble finding stuff.
First, the manual says there is a terminal to which you apply power and test the fuel pump. There is a really bad drawing of it, and no description of where this terminal actually is. Best I can tell from the drawing, it should be on the firewall, but I can't find it. Am I looking in the right spot?
Also, I want to test the fuel pump relay. From what I've read it is located behind the inside kick panel on the right side front foot well, in front of the door speaker. I pulled the panel off and found what appears to be an ECU (transmission?), not the relay that I saw in a couple pics. Am I looking in the right spot for this as well?
Any input appreciated.
Re: Troubleshooting fuel pump (Gen2.5 Montero) [Re: Mudpie] #1101642 06/30/16 04:05 PM
P
pcc Offline
Do you have spark? If no spark then computer may not allow fuel pump to operate. I'd check spark first.
Re: Troubleshooting fuel pump (Gen2.5 Montero) [Re: Mudpie] #1101645 06/30/16 06:41 PM
off-roader Offline
Did you try to listen for the pump by opening the Fuel filler tube?
That's the first thing I'd do.
Off Roader
96SR (3.15:1 xcase, 35's)
96SR Build Up Thread
Old web page
Old web page
Re: Troubleshooting fuel pump (Gen2.5 Montero) [Re: Mudpie] #1101669 07/01/16 06:21 PM
Mudpie Offline OP
Just an FYI, my computer has fried the motherboard, and I haven't got a new one yet. I'm using the computer at the library, and there's a time limit. As such, my ability to search for answers is limited. Sorry in advance if I'm asking something that should be easy to find.
This is where I'm at...
I found the fuel pump test terminal. It was kind of where the drawing in the manual showed it to be, but it was buried in the wiring loom. Applied power to it, and no fuel pump.
Pulled the tank access panel, pulled the plug off the pump and applied power directly and it seems to work. I have no idea how much pressure it's making since the '99 Montero has no Schrader valve on the fuel rail.
Checked for spark, with new plugs. Pulled #1 since it was easiest to get to. There was a spark arcing between #1 and #5 on the coil pack. Pulled the #5 wire off the coil pack and the arcing stopped, but I never got a spark at #1.
I tried reading through the manual online, but due to my time limit I didn't get too far. From what I've read the fuel pump/MFI relay controls both the fuel pump and power to the ECU, so a bad relay would explain my current problem. When I bought it, the previous owners daughter said "it just stopped" when she was driving it.
My current issue is getting to the relay. It's buried in the dash, with no obvious way to get to it. I can see it, but can't even get a finger on it, let alone unbolt or unplug it. Do I have to pull the dash to get to this stupid relay?
Any thoughts appreciated. I wanna go wheelin'...soon!
Re: Troubleshooting fuel pump (Gen2.5 Montero) [Re: Mudpie] #1101670 07/01/16 06:57 PM
P
pcc Offline
Sounds like waste spark system, spark to two plugs whether they need it or not. I don't understand what/why you got, but research waste spark.
Did you actually ground the plug with wire attached to see spark?
Re: Troubleshooting fuel pump (Gen2.5 Montero) [Re: pcc] #1101671 07/01/16 08:18 PM
ryany Offline
As stated above, have you already confirmed that the fuel pump is not working when you turn the key on?
95 Montero SR 3.5
Re: Troubleshooting fuel pump (Gen2.5 Montero) [Re: Mudpie] #1101683 07/02/16 02:57 AM
Mudpie Offline OP
Well, I thought I had confirmed. I'm using a crappy test light. I bought a decent meter and checked again and I am getting power to the fuel pump when I crank the motor.
I'm still not getting any spark though. I did ground the plug, and moved the wire to each of the 3 coil packs to check. No spark anywhere.
I had considered just spending the $23 for a new relay when I thought that was the problem. Good thing I can't get to it I suppose or I'd be out 23 bucks. Right now I'm thinking ignition module maybe, but I'm definitely not spending $130 to get one on a hunch. I hate diagnosing by simply throwing money at something.
I'll hit up the library tomorrow and see what I can find for any further testing info, but I'm open to suggestions. As I said, I've never worked on one of these. I'm a Volvo guy. Their little problems and common issues I'm pretty familiar with. The Montero, not at all.
Thanks for the help. I appreciate any input.
Re: Troubleshooting fuel pump (Gen2.5 Montero) [Re: Mudpie] #1101684 07/02/16 10:43 AM
P
pcc Offline
You'd have to check from the coil pack primary volatge back. I'm not familiar with your system but the basics are the same. Primary voltage switches on/off to coil. The computer switches the voltage, usually by ground switching as positive voltage is constant connection.
Re: Troubleshooting fuel pump (Gen2.5 Montero) [Re: Mudpie] #1101689 07/02/16 09:43 PM
Mudpie Offline OP
I managed to get the entire electrical section of the factory manual printed out. Hopefully that will have all the procedures for testing. Hard to have confidence though when the factory manual advises in the ignition troubleshooting section to check the coil and distributor.
The vehicle has multiple coils, and no distributor. Great publication Mitsubishi.
Re: Troubleshooting fuel pump (Gen2.5 Montero) [Re: Mudpie] #1101690 07/02/16 10:07 PM
P
pcc Offline
Going back to your description of the arc between coil connections. Check for cracks in the coil pack.
PHP: 7.2.31 Page Time: 0.032s Queries: 16 (0.009s) Memory: 2.8904 MB (Peak: 3.1637 MB) Data Comp: Off Server Time: 2020-06-04 18:13:25 UTC
