2.6 balancer bolt
monty build thread
by motero - 11/30/21 07:57 PM
Happy Turkey Day
by motero - 11/30/21 07:45 PM
by motero - 11/22/21 08:28 PM
JK Check Engine Light - P0300
2.6 balancer bolt
monty build thread
Happy Turkey Day
1991 Diesel Swap
0 registered members (), 84 guests, and 4 spiders.
Topics138,250
Posts1,081,587
Members15,228
Page 2 of 2 1 2
Re: 97 montero sr Any one added a fan or two? [Re: ES_97Sport] #1101666 07/01/16 04:17 PM
MMeadows Offline OP
Originally Posted by ES_97Sport
That's what I thought. Yea, the OP would probably be better off looking through the Cherokee threads. Lots of info on there about transmission coolers.
What I got off those threads was to pull the transmission out of the radiator and install a standalone cooler. About half put one in front of the condenser/radiator. The guys running 37/38+ tires install a separate cooler with its own fan and put it where it'll fit.
Mitsu never did a deep sump pan for the AW3, but there is a company out there that does sell one. The dipstick is on the PS side though. For whatever its worth. General opinion seemed to be leaning towards that not being worth the effort - what was really needed was a separate cooler and/or fan.
I'm not a huge fan of the in-radiator cooler. It is nowhere near as efficient as a properly installed stand-alone unit.
Edward
It looks like my montero comes with a stock cooler and it also runs into the radiator as well. So the suggestion would be to add a 2nd cooler with a fan, and leave the oem cooler without a fan?
I did a full flush and the fluid was brown, didnt smell but was not red. I have a trip coming up this weekend ill see how it goes. You do have my worried about my radiator now though.
97 Montero SR: 2in body lift. 33" KM2
Re: 97 montero sr Any one added a fan or two? [Re: MMeadows] #1101672 07/01/16 08:25 PM
ES_97Sport Offline
Originally Posted by MMeadows
... It looks like my montero comes with a stock cooler and it also runs into the radiator as well. So the suggestion would be to add a 2nd cooler with a fan, and leave the oem cooler without a fan?
No, you're not supposed to run multiple coolers. Besides causing flow restrictions, multiple coolers and all the line will themselves raise the temperature of the fluid. For all that I've ever heard or read, this is considered pretty much universally to be a 'bad idea'.
For me - I'm building a '99 Sport on 37"s with the same transmission you have - I'm going to pull the A/T stuff out of the radiator and run a big aftermarket in front of the condenser. If it'll fit and if it doesn't restrict air flow to the condenser and radiator. Plan 'B' is a big cooler with a fan mounted, uh, somewhere. I haven't figured the 'where' out yet. laugh
That was the decision I arrived at after pouring though Pirate, 4MUD, the AW4 forums, towing forums and talking to the A/T shop that builds these for off-road use and talking to the Jeep shops.
What you're describing sounds a lot like what I've seen out with the Cherokee/Toy guys off road. The idea behind the in-radiator cooler is that it warms the fluid up when its cold, and cools the fluid when its hot. That's the one benefit of the in-radiator cooler over a passive A/T cooler - it works even when you're standing still. Mostly. laugh
You MAY be having a problem with the radiator. I'm religious when it comes to fluid flushes but most people are not and that leads to scale and crud build up especially in the radiator and since the in-radiator cooler isn't that efficient it doesn't take much to affect it.
I would run an OBD scanner and monitor ECT over a good period of time under various conditions and see if the average coolant temp is elevated. If so you could kind of infer that the radiator is either dirty internally and/or externally and needs cleaned - assuming of course, that everything else is sound.
Which brings up something else to check. Either the condenser or radiator or both may be full of bugs, leaves, dirt, mud, etc. restricting air flow just enough that you're starting to see the beginnings of a cooling problem. Easy enough to fix - remove the radiator and take a garden hose or a pressure washer on low and flood water through the fins in reverse of air flow. Leave the condenser installed and do the same for it before you reinstall the radiator. This is probably something that is long overdue in anyway. laugh
In any case, if I were going to off-road the AW4 I would get a real cooler and use that. Its a good transmission and the only time anyone really has issues with it is when its overheated. I know guys here in CO that run 37, 38 and 40 inch tires on it and have for years without issue but they run big coolers.
Edward
'03 Montero Sport Limited AWD
Re: 97 montero sr Any one added a fan or two? [Re: MMeadows] #1101681 07/01/16 11:58 PM
fasteddy Offline
Ditto. Note that the at temp sensor is known to trip when wet, worth checking, or use a gauge and sender.
Re: 97 montero sr Any one added a fan or two? [Re: MMeadows] #1101820 07/23/16 02:08 PM
MMeadows Offline OP
the 97 montero sr comes with a transmission cooler stock, Is it advisable to replace it with a bigger one or simply add a fan? Id imagine the fan would offer more cooling power and adding more volume would. Ive also heard its best to add a fan on the back side of a cooler to not restrict air flow coming from the front.
Re: 97 montero sr Any one added a fan or two? [Re: MMeadows] #1101837 07/27/16 09:56 PM
ES_97Sport Offline
Put a A/T temperature gauge on your transmission. A good one, not a cheap POS. That will tell you whether or not you need to be touching anything.
Pusher fans are not nearly as efficient as puller fans. As a rule of thumb, you always want an electric fan to pull air.
Edward
Re: 97 montero sr Any one added a fan or two? [Re: MMeadows] #1101842 07/28/16 09:06 PM
MMeadows Offline OP
Does the stock a/t temperature unit record temps that a Bluetooth odb reader could display or does it just turn a light on after it reaches a threshold?
Re: 97 montero sr Any one added a fan or two? [Re: MMeadows] #1101851 07/29/16 05:56 PM
ES_97Sport Offline
As far as I know from my research, and someone please correct me if I'm wrong 'cause I want to know the definitive answer to this, too, the answer is no. The older systems were made up of a ECM (engine control module) and a TCU/TCM (transmission control unit/module) with a buss line between the two. OBD didn't extend to the TCU.
Edward
Page 2 of 2 1 2
PHP: 7.2.34 Page Time: 0.031s Queries: 16 (0.010s) Memory: 2.8837 MB (Peak: 3.1637 MB) Data Comp: Off Server Time: 2021-12-05 18:08:44 UTC
