Reloading - My Observations
Water temperature sensor
Happy Holidays
by plh - 12/29/21 11:04 PM
Early Gen I trim levels
Happy Holidays
2 in lift kit worth it?
0 registered members (), 55 guests, and 4 spiders.
Topics138,256
Posts1,081,615
Members15,240
help running hot 2001 #1101881 08/06/16 02:36 PM
TainterRacing Offline OP
What it is doing is worth the ac on it s ruining hot. The condenser fan some times comes on. Shouldn't the condenser fan ruin when the ac is on...
What I have done is flushed radiator bled it. New temp sensor fixed the gauge cluster and I in stalled a new thermostat. I need to replace the fan clutch I think.
The condenser fan was froze up and the guide was blown. Replaced fan and fuse. It's always hot when the condenser fan is not on.
Re: help running hot 2001 [Re: TainterRacing] #1101882 08/07/16 12:35 AM
Mudraider Offline
Sounds like typical Mitsubishi wiring issues.
Re: help running hot 2001 [Re: TainterRacing] #1101883 08/07/16 12:49 AM
4x4Wire Offline
Actually, it is a noted issue and your best bet is to install a secondary temperature sensor that will read the coolant temp without feeding the results back through the cluster gages and lights.
Your temp may actually be within factory specs....
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: help running hot 2001 [Re: TainterRacing] #1101884 08/07/16 06:18 PM
Why is the condenser fan not on?? with the A/C? all the time.
Re: help running hot 2001 [Re: TainterRacing] #1101887 08/08/16 07:02 PM
4x4Wire Offline
In the search block, enter the phrase
2001 Montero overheating
A number of links appear....
Here is one....
http://www.4x4wire.com/forums/ubbthreads.php/ubb/showflat/Number/1225257/site_id/1#import
John Stewart
Editor - 4x4Voice
Re: help running hot 2001 [Re: TainterRacing] #1101888 08/09/16 01:32 AM
My guage is reading right I fixed that. It runs like 205-209 not crazy hot but its only when the condenser fan is not on.
Re: help running hot 2001 [Re: TainterRacing] #1101890 08/10/16 08:41 PM
ES_97Sport Offline
The condenser fan does not run constantly when the A/C is on. Someone please correct me if I'm wrong, but I believe when the fans runs is based on the pressure in the A/C system.
... I need to replace the fan clutch I think. ....
That would be high on my list. smile
Edward
'03 Montero Sport Limited AWD
PHP: 7.2.34 Page Time: 0.028s Queries: 15 (0.009s) Memory: 2.8517 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2022-01-21 19:44:11 UTC
