Search 4x4Wire
correct idle RPM for 91 Montero
by jeffmort. 01/20/18 05:32 PM
ECU code reading - first timer rookie
by jeffmort. 01/20/18 08:19 AM
Carb Question
by 87Raider. 01/20/18 04:06 AM
Stalling 1989 Raider
by cheesegrater. 01/19/18 01:32 PM
relay module ID - need help
by jeffmort. 01/19/18 06:51 AM
Ranger .22 Pump-Action Rifle?
by lupacexi. 01/19/18 04:10 AM
CanCooker Recipe for January 2018
by 4x4Wire. 01/17/18 09:50 PM
My '88
4x4Wire YJ
0 registered members (), 141 guests, and 7 spiders.
Topics137,740
Posts1,079,158
Members14,725
Rate This Thread
#1101891 - 08/11/16 05:46 PM Clutch getting stuck
mfarmer10  Offline
Southern Pines, NC
Hey, I was just driving my 89' Raider V6 and the clutch pedal just got stuck to the floorboard and no longer had any tension, couldn't change the gears. I turned the truck off, pulled it back out and restarted it and it seems fine. Any idea of what this could be? I haven't any issues in quite a while but of course when I have a 4 hour drive coming up the issues start happening. definitely want to get this taken care of before hand
#1101892 - 08/11/16 07:43 PM Re: Clutch getting stuck [Re: mfarmer10]
cheesegrater  Offline
Franklin IN
I just went out and looked at mine and it appears that it is a hydraulically actuated clutch. I'm wondering it maybe the pivot for your pedal might be rusted or galded at the shaft.
#1101895 - 08/13/16 04:58 PM Re: Clutch getting stuck [Re: mfarmer10]
rxinhed  Offline
Gerber, CA *****
After (1989 to 2016), the most likely culprit will be your clutch hose swelling shut and not letting fluid pass.
1980 Power Wagon W400
Sundry Mitsubishi Montero Gen 1 parts
Parts vehicles: 1980 D50 2wd, 1988 Mighty Max 4wd, 89 LS Montero 4-door, 2002 Sport AWD
For Sale: 1989 Power Ram 50 extended cab
#1101900 - 08/14/16 08:16 PM Re: Clutch getting stuck [Re: mfarmer10]
Mudraider  Offline
Orange Park, FL
So, what did you find?
#1101906 - 08/16/16 08:03 PM Re: Clutch getting stuck [Re: mfarmer10]
djacidjac  Offline
PA USA
Mine did that. but the pedal itself would come back up. I had a leaky slave cylinder. Can you pull the pedal up with your toe and pump it a few times to get pressure? I could pump mine and then it'd work for a bit. Drove 1.5 hours home like that. Almost ran into the jeep in front of me on the trail too. I replaced the cylinders and the hose.
OBA (stock AC compressor)
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.008s Queries: 15 (0.003s) Memory: 0.8125 MB (Peak: 0.9100 MB) Zlib disabled. Server Time: 2018-01-20 20:47:03 UTC
