Search 4x4Wire
Weber 32/36 DGV vs DFV
by Mudraider
Today at 02:27 AM
Kia Sportage SOHC 2.0 to DOHC 2.0 Motor Swap
by Coy77
Yesterday at 11:07 PM
Stubborn Pully/Balancer Bolt; no f-bomb yet...
by dfreem01
Yesterday at 02:57 AM
Hayabusa 2008 rods $368.00USD in US
by Racerfanny
Yesterday at 02:04 AM
HELLWIG INTRODUCES AIR SPRINGS FOR THE 2016 NISSAN
by 4x4Wire
01/18/17 06:32 PM
Introducing the RV 770 LMT-S Navigator
by 4x4Wire
01/17/17 08:46 PM
1992 Pajero autolockers
by Mudraider
01/17/17 03:59 PM
by Coy77
by Racerfanny
by 4x4Wire
01/18/17 06:32 PM
by 4x4Wire
01/17/17 08:46 PM
by justforfun
01/16/17 12:13 AM
Gen 2 & Gen 2.5 rear axle
by JeffatTireBalls
01/15/17 06:30 PM
My '88
4x4Wire YJ
IFS Holdout
Who's Online
0 registered (), 94 Guests and 8 Spiders online.
Forum Stats
14,605 Registered Members
38 Forums
136,972 Topics
Most users ever online: 367 @ 12/16/16 07:24 PM
Topic Options
Rate This Topic
#1102739 - 01/06/17 04:26 AM Acceleration Explained
4x4Wire Offline
Loc: Lakeside, CA ***
Ever wonder why a Top Fuel dragster gets a rebuilt engine after each run?
Stay with this - even if you aren't a 'car nut', this is stunning.
One Top Fuel dragster outfitted with a 500 cubic-inch replica Dodge (actually Keith Black, etc) Hemi engine makes more horsepower (8,000 HP) than the first 4 rows of cars at NASCAR's Daytona 500.
Under full throttle, a dragster engine will consume 11.2 gallons of nitro methane per second; a fully loaded Boeing 747 consumes jet fuel at the same rate but with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to even drive the Dragster's' supercharger.
With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lockup at full throttle.
At the stoichio-metric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, disassociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug, which is typically the output of a small electric arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass. After 1/2 way thru the run, the engine is 'dieseling' from compression and the glow of the exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with enough force to blow the cylinder heads off the block in pieces or split the block in half!
Dragsters reach over 300 MPH + ... before you have completed reading this sentence.
In order to exceed 300 MPH in 4.5 seconds, a dragster must accelerate an average of over 4 G's. In order to reach 200 MPH well before reaching half-track, at launch the acceleration approaches 8 G's.
Top Fuel engines turn approximately 540 revolutions from light to light!
Including the burnout, the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9500 RPM.
THE BOTTOM LINE: Assuming all the equipment is paid for, the pit crew is working for free, and NOTHING BLOWS UP, each run will cost an estimated $1,000 per second.
0 to 100 MPH in .8 seconds (the first 60 feet of the run)
0 to 200 MPH in 2.2 seconds (the first 350 feet of the run)
6 G-forces at the starting line (nothing accelerates faster on land) 6
negative G-forces upon deployment of twin 'chutes at 300 MPH.
An NHRA Top Fuel Dragster accelerates quicker than any other land vehicle on Earth ...
Quicker than a jet fighter plane ...
Quicker than the space shuttle ...
Or snapping your fingers!
The current Top Fuel dragster elapsed time record is 4.42 seconds for the quarter-mile (2004, Doug Kalitta). (I think the time is now closer to 4 seconds, as of Winter 2014.)
The top speed record is 337.58 MPH as measured over the last 66' of the run (2005, Tony Schumacher).
Update: Only going 1000 feet (320 feet less than 1/4 mile) they do it in 3.7 seconds at around 332 mph with 10,000 horse power with 90% nitro - methane 10% alcohol.
THEY THOUGHT THEY WERE GOING TOO FAST FOR 1/4 MILE AND COULDN'T STOP.
Let's now put this all into perspective:
Imagine this: You're driving a new $140,000 Lingenfelter twin-turbo powered Corvette Z-06. Over a mile up the road, a Top Fuel dragster is staged and ready to 'launch' down a quarter-mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard, on up through the gears and blast across the starting line and pass the dragster at an honest 200 MPH. The 'tree' goes green for both of you at that exact moment. The dragster departs and starts after you. You keep your foot buried hard to the floor, and suddenly you hear an incredibly brutally screaming whine that sears and pummels your eardrums and within a mere 3 seconds the dragster effortlessly catches
and passes you. He beats you to the finish line, a quarter-mile away from where you just passed him. Think about it from a standing start, the dragster had spotted you 200 MPH. And it not only caught, but nearly blasted you off the planet when he passed you within a mere 1320 foot long race!
That, my friends is acceleration.
_________________________
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
CFWDA Resources Consultant
Top
Moderator:  52degrees, Adam F, Axe Man, kewlynx
  • 1
Jeep Tech from JeepWire Read More
Toyota 4x4 Tech
Toyota 4x4 Tech
Toyota Tech from 4x4Wire Read More
Mitsubishi 4x4 Tech
Mitsubishi 4x4 Tech
Mitsubishi Tech from 4x4Wire Read More
Isuzu Tech from 4x4Wire Read More
  • 1
Search the 4x4Wire site:
4x4Wire Social: | 4x4Wire on FaceBook | Google+4x4Wire on Google+
OutdoorWire, 4x4Wire, JeepWire, TrailTalk, MUIRNet-News, and 4x4Voice are all trademarks and publications of OutdoorWire, Inc. and MUIRNet Consulting
Copyright (c) 2000-2016 OutdoorWire, Inc and MUIRNet Consulting - All Rights Reserved, no part of this publication may be reproduced in any form without express written permission
