Adjustable Upper Control Arms TRC540
Following on from the success of the Ford and Toyota range of Adjustable Upper Control Arms SuperPro is pleased to announce the release of the Nissan Navara D40, NP300 and Nissan Pathfinder R51 Adjustable Upper Control Arms. Previously made from steel tube welded to a forged steel ball joint plate, the new arms utilise the manufacturing method developed and refined with the Ford and Toyota arms. They are built tough in Australia using high strength, OE grade Aussie steel.
Getting the correct alignment is no longer a problem and the design of these  Arms overcome clearance issues. These arms deliver up to 3 degree of caster along with extra camber, allowing for the optimum alignment settings for a 2” lifted vehicle. Not only do these arms provide for better wheel alignment settings, they have been designed to include increased clearance between the arm and strut at full droop.
Key Features
• Increased articulation, perfect for the off road environment
• In-built camber and caster change to suit lifted vehicle
• Provides for camber and caster adjustment using an adjustable ball joint
• Increased clearance between spring and Control Arm at full articulation
• SuperPro Bushings
• Made in Australia
See more at: SuperPro
