by 0778drz110. 02/17/18 02:58 AM
by 4runnernomore. 02/16/18 10:48 AM
6g72 SOHC - Blowing Head Gaskets - Why?
by rxinhed. 02/16/18 01:35 AM
Here's a shot...
by 0778drz110. 02/15/18 03:21 AM
95 SR Intake Plenum
by rxinhed. 02/15/18 03:14 AM
Gen1-- My left knee opens windows
by rxinhed. 02/15/18 03:08 AM
95 SR Plenum Fix for $70
by PTaylor525. 02/14/18 05:36 PM
by tdf46. 02/14/18 07:56 PM
by PTaylor525. 02/14/18 05:31 PM
4DR50 Diesel motor
by soclair. 02/14/18 05:19 PM
by Bluuplanet. 02/13/18 07:49 AM
95 SR Intake Plenum
by PTaylor525. 02/08/18 03:54 AM
Here's a shot...
by dadrab. 02/07/18 02:34 PM
My '88
4x4Wire YJ
0 registered members (), 161 guests, and 7 spiders.
Topics137,791
Posts1,079,269
Members14,729
Rate This Thread
#1103734 - 08/13/17 12:37 AM kia sportage not disengage 4H to 2H
jckiasportage  Offline
Guatemala
Hello to all,
I am new on this forum, I know you are very much experienced owners of Kias that could help me.
I own a Kia Sportage 1997 runs OK in 4H mode, the problem occurs when I trying to come back to 2H because the hubs not disengage... they disengage after too many tries (some times trying for hours...), that seems to me an abnormal condition.
For these days I am changing the clutch and seized the oportunity to take a glance to the transfer to look for an anormal conditions that might cause the problem, but I saw nothing...
Any ideas why this is happening?
I would like to fix the problem and conserve the original system but want to examine my options and one of them seems to be switch the system to manual hubs...
What do you recomend me?
Thank you in advance!
Kia Sportage 1997 , 4" UPYOURKIA lift kit, rear TJ Wrangler 3227's, rear KYB 99 RAV4, 3.25" body lift, 265/75/16 tires, snorkel, 5.38 R&P, front/rear TF-Lockers. Working @: custom front/ rear bumpers, Superwinch Tiger Shark 9500 w/remote control.
#1103801 - 09/01/17 10:41 AM Re: kia sportage not disengage 4H to 2H [Re: jckiasportage]
4runnernomore  Offline
Darwin Australia
Have you checked your front hubs. Pull them apart a d give them a good clean up and service.
Are they vacuum activated or mechanical?
If they are vaccum check for any leaks.
Easiest optio is to fit freewheeling hubs ? I think that will solve your issues. Factory hubs have been know n to be problematic.
3 options for free wheelin hubs
AVM
Warn
Mazda B2000 with a couple of small mods
Cheers, Chris
97 Sporty, snorkel, K&N filter, 98 power chip, ext forks, 40mm Dobinson Springs, KYB struts, 35mm Jeep TJ Dobinson Springs, RAV 4 OME shocks, Kaiser Flocker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, Fully Engineered
#1103972 - 11/07/17 12:11 AM Re: kia sportage not disengage 4H to 2H [Re: jckiasportage]
logansportage  Offline
Logan, Utah
Check under the hood of the car on the side opposite of the battery for the vacuum actuator. It's by the break master cylinder. Look at the hoses for cracks and also check down at the front suspension out to the wheel hub for cracks in the hoses there. The internal hubs are a dual diaphragm design and do get contamination in them that will not allow them to seal to activate because there is not enough vacuum. They will also not deactivate if there is not enough pressure.
The best solution is to switch to the free wheeling hubs. They are much more reliable and are stronger too.
Logansportage
Moderated by  Axe Man, DamKia
Page Time: 0.008s Queries: 15 (0.003s) Memory: 0.7937 MB (Peak: 0.8715 MB) Zlib disabled. Server Time: 2018-02-21 17:16:16 UTC
