Gen1 2.6L alternator upgrade
by rascott. 09/19/18 05:27 AM
WTB: Mitsubishi Gen1 seatbelt
fuel tank/ separator tanks
by rxinhed. 09/06/18 04:00 AM
1989 LWB A/T Temp Light
Echo
89 Trooper wiring question
by Resman7. 09/05/18 11:48 AM
Gen 1 & 2 Monteros for sale
by . 08/25/18 02:30 PM
0 registered members (), 136 guests, and 6 spiders.
Topics137,912
Posts1,079,635
Members14,783
Page 16 of 16 1 2 14 15 16
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: fhuzz] #1079632
11/26/15 08:26 PM
11/26/15 08:26 PM
rxinhed  Offline
Gerber, CA *****
I might have a shifter, but nothing deeper into the t-case without opening one up.
1980 Power Wagon W400
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: rxinhed] #1079639
11/30/15 06:31 PM
11/30/15 06:31 PM
F
fhuzz  Offline
richmond hill, ontario
I should clarify. It's a part of the 'linkage' that is external to the t-case running under and perpendicular the transmission.
A metal rod connected between two other metal rods, with a spring running inside the middle rod.... I hope that makes sense.
A while ago I had some work done on the transmission and this rod and associated inner spring have a lot of slack.
'89 Monty LWB auto, 3rd row seating, 95SR rear + coils, genII UCA's and calipers/rotors, dual bouncies.
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: LandRaider] #1079658
12/03/15 09:10 PM
12/03/15 09:10 PM
Maciek  Offline
Seattle, WA
$10 should cover it
~M
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: LandRaider] #1079659
12/03/15 09:28 PM
12/03/15 09:28 PM
Maciek  Offline
Seattle, WA
welcome newbie, sorry i dont' check in often, but if JAYVYPRO already got one this one's yours.
Head issues are pretty common on the 2.5. Check the torque on the head bolts. If it is cracked I would look in to the jet-valve free head. There are some options there, some castings are better than others, but any is better than stock with jet valves. Pricing varies too, complete ready to go can get expensive (especially if you look at fancy valve, spring, and rocker/lifter options), and bare castings aren't that cheap unless you can do the valve work yourself. I got mine for less than 300 (not incl core) (from Odessa cylinder head) set up with stock valves and springs, so all I had to do was check the oil passages are all clear and swap my rocker train over and it was good to go. Even got it through emissions here in WA a couple times before it got old enough not to require it anymore.
GL
~M
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: LandRaider] #1101908
08/17/16 07:21 PM
08/17/16 07:21 PM
bahamaraider  Offline
bahamas
new to this forum
I am looking for a drivers side vent window and passenger side mirror for my 87 dodge raider.....any info would be greatly appreciated. it seems the mirrors are rare.
good morning
I have a red 1987 dodge raider....bought it 3 years ago...only major problem was the carburetor...went to a weber and had no problems since then....working for the navy in the Bahamas...my raider is perfect for the island.
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: LandRaider] #1101909
08/17/16 11:44 PM
08/17/16 11:44 PM
TOASTY  Offline
Mesa AZ, US. *****
This is a thread about paying it forward and giving things away to the community, If you are wanting parts you should try the wanted section OR read through this thread and find someone giving the parts you want away and contact them directly.
1999 Montero Blizzard package
2005 Montero Limited
2015 Mirage with antifreeze Sparco wheel package
Re: New and Improved!!! "Pay It Forward 2010" A thread of goodwill, and freebies [Re: LandRaider] #1103936
10/20/17 02:43 AM
10/20/17 02:43 AM
rxinhed  Offline
Gerber, CA *****
Back from the dead again, this thread.
I have a Montero Sport parts car aching to donate useful things
Page Time: 0.016s Queries: 16 (0.009s) Memory: 1.0476 MB (Peak: 1.1640 MB) Zlib disabled. Server Time: 2018-09-22 14:59:28 UTC
