Search 4x4Wire
Fuel filter problem
by Rocker. 01/23/18 06:31 AM
Carb Question
by rxinhed. 01/21/18 06:06 PM
correct idle RPM for 91 Montero
by rxinhed. 01/21/18 06:02 PM
CA: 89 SWB V6 Need Washer Fluid Container
by rxinhed. 01/21/18 06:01 PM
Stalling 1989 Raider
by cheesegrater. 01/21/18 12:58 PM
relay module ID - need help
by dfreem01. 01/21/18 04:27 AM
lugs for aftermarket alloy wheels?
by rxinhed. 01/21/18 12:36 AM
by jeffmort. 01/20/18 05:32 PM
ECU code reading - first timer rookie
by jeffmort. 01/20/18 08:19 AM
by cheesegrater. 01/19/18 01:32 PM
by jeffmort. 01/19/18 06:51 AM
Ranger .22 Pump-Action Rifle?
by lupacexi. 01/19/18 04:10 AM
CanCooker Recipe for January 2018
by 4x4Wire. 01/17/18 09:50 PM
My '88
4x4Wire YJ
0 registered members (), 126 guests, and 5 spiders.
Topics137,740
Posts1,079,181
Members14,725
Rate This Thread
#1103983 - 11/16/17 12:32 AM Body mounts
Montero84  Offline
USA
Hello, everyone.
Does any one have experience replacing the body mounts on a Montero Gen1? I know many have installed lift kits, but that would involve disconnecting many things from the vehicle. I am wondering if replacing the body mounts would also involve disconnecting the fuel tank, radiator hoses, etc or if it just a matter of unbolting the body mounts, lift the body a little bit and replace the body mounts.
Thanks in advance.
#1103985 - 11/16/17 05:15 AM Re: Body mounts [Re: Montero84]
rxinhed  Offline
Gerber, CA *****
You should be able to wiggle the OE mounts out, so long as the metal sleeve within cooperates.
1980 Power Wagon W400
Sundry Mitsubishi Montero Gen 1 parts
Parts vehicles: 1980 D50 2wd, 1988 Mighty Max 4wd, 89 LS Montero 4-door, 2002 Sport AWD
For Sale: 1989 Power Ram 50 extended cab
#1103997 - 11/29/17 05:42 AM Re: Body mounts [Re: Montero84]
djacidjac  Offline
PA USA
I'm pretty sure you could jack up each side of the body just enough to make it easier without disconnecting anything. Follow the method in the body-lift how-to: remove all the nuts, jack up one side with a 4x4 post along the rocker panel pinch seem and swap out al the mounts on that side. then switch to the other side. In your case only jack as necessary. I'm guessing no more than a half an inch.
OBA (stock AC compressor)
Powered by UBB.threads™ PHP Forum Software 7.6.0
Page Time: 0.007s Queries: 16 (0.002s) Memory: 0.7948 MB (Peak: 0.8795 MB) Zlib disabled. Server Time: 2018-01-23 09:38:42 UTC
