Starter motor are they serviceable ..
by rxinhed. 04/17/18 03:14 AM
Considering Part-Out...
by rxinhed. 04/12/18 12:34 AM
by rascott. 04/11/18 08:44 AM
1999 Montero Sport Limited 3.5L crawler build
by ES_97Sport. 04/11/18 12:56 AM
by JeffatTireBalls. 04/08/18 02:57 PM
87Monty will have a 4BT
by JeffatTireBalls. 04/08/18 02:50 PM
Tuning up 4D56T
by red1987raider. 04/02/18 12:41 AM
by 4runnernomore. 04/16/18 01:49 PM
by DRTDEVL. 04/06/18 02:04 PM
Tuning up 4D56T
R&P Contact Pattern
by JeeperDan. 03/15/18 01:14 PM
by rxinhed. 05/01/16 12:11 AM
My '88
4x4Wire YJ
0 registered members (), 48 guests, and 6 spiders.
Topics137,824
Posts1,079,359
Members14,753
New Gen 3!... (but stuck in 2wd) what gives?? #1104035
12/28/17 07:12 PM
12/28/17 07:12 PM
F
fatdonkey  Offline OP
Oregon
Seeking guidance from the Montero-wise.
I'm stumped. Picked up a 2003 Montero with only 75k miles, had it shipped over to the NW from Hawaii.
Not sure it's ever been in 4wd in it's entire life. Here's the symptoms.
-Flashing center differential light, all green wheel lights go out. Checked codes by grounding pins 1&4. Codes 33 & 35.
-Changed Front diff vacuum solenoid under airbox (did not fix). Cleaned out old solenoid, cleaned connectors (did not fix).
-When switching into 4 wheel drive the transfer case is silent, stays in 2wd no matter what selection.
-I checked the front diff actuator shaft for corrosion, was clean but I regreased anyways and manually cycled by sliding the shaft by hand.
-All vacuum lines are in place and seem to be intact.
-I've cycled the transfer case lever 100+ times back and forth in the last 2 weeks to no avail
-I've drained & replaced the transfer case fluid with GL4 (no changel)
Next steps:
Clean all electrical connections around the vacuum solenoid and use dielectric grease to seal
Switch the vacuum lines on the solenoid and check to see if the front diff engages
If all else fails, try drop the transfer case and clean the switch connections with electrical connector cleaner
Does anyone have insight or direction for me? Thank you in advance!
99 Montero Winter Package
Re: New Gen 3!... (but stuck in 2wd) what gives?? [Re: fatdonkey] #1104045
01/04/18 01:40 AM
01/04/18 01:40 AM
rxinhed  Offline
Gerber, CA *****
Take off the t-case selector and look inside the mount? Perhaps it's just gummed up. My second LUV had that problem, just trying your troubleshoot.
1980 Power Wagon W400
Sundry Mitsubishi Montero Gen 1 parts
Parts vehicles: 1980 D50 2wd, 1988 Mighty Max 4wd, 89 LS Montero 4-door, 2002 Sport AWD
For Sale: 1989 Power Ram 50 extended cab
Page Time: 0.009s Queries: 16 (0.003s) Memory: 0.9793 MB (Peak: 1.0482 MB) Zlib disabled. Server Time: 2018-04-20 01:21:35 UTC
