Replacement MAF unit .. Gen1
Gen1 cigarette lighter port.
GEN I Auto hubs
by polar - 02/16/21 06:55 PM
by polar - 02/16/21 03:03 AM
GEN I Auto hubs
0 registered members (), 108 guests, and 3 spiders.
Topics138,176
Posts1,081,000
Page 4 of 4 1 2 3 4
Re: Winch w stock bumper [Re: Guns_and_Roses] #981388 02/11/10 03:52 PM
lordtrunks Offline
not sure if your talking bout mine or his but mine came off a full size truck its about 30 years old. These worm gear winches are awesome very slow but like the m.m. hyd. winches you can just rip houses down all day long without a break and they don't care, only thing is our alts can't keep up with them or any winch so all day winching is out.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Winch w stock bumper [Re: Angelo] #981389 02/11/10 04:48 PM
87Montero Offline
first off, TJM is very rare to even find on a vehicle. Second, you found one at a junk yard. Third, you got it for $50!! You were extremely lucky! Sweet find for sure! Glad to see you aren't wasting any time. Is that the new "Marn" winch? <img src="/forums/images/graemlins/lol.gif" alt="" />
Yeah I'm kind of jealous!!! I wish I got my new TJM for $50! <img src="/forums/images/graemlins/scared.gif" alt="" />
1999 Mitsu Montero - Crappy Weather
1992 Isuzu Pickup - Zombie Apocalypse
2008 Saturn Sky Redline - Nice Weather
Re: Winch w stock bumper [Re: LandRaider] #981390 02/11/10 05:30 PM
hazy_daze Offline
What did that winch come from?
They're typically found on wreckers and tow trucks. Work REALLY good.
Re: Winch w stock bumper [Re: 89montero] #1104156 02/03/18 05:13 AM
djacidjac Offline
I bought a harbor freight winch and winch plate, then cut the plate in such a way that the "L" shaped pieces cut off each end stand up vertically (and get welded on). I bolted the flat plate to the bottom of the frame at the factory winch mount holes, and I bolted the new 'uprights' to the inner sides of the frame at the factory weld-nuts there. those require half-inch spacers because the frame rails get narrow right there. I used some short pieces of pipe "temporarily" for several years and haven't had the need to put a flat piece of half-inch steel in there like I intended. I have used this setup to winch the Raider out stuck good a few times and some other trucks mildly stuck and a whole bunch of weird / fun utility stuff. A note about the old HF winch I got; they made their own solenoid switching assembly, it's pretty beefy with thick brass plates and contactors. It only uses two solenoids in a push/pull arrangement and that's how it can reverse. The whole switching can be rebuilt using only a small flat-blade screwdriver. I remotely mounted the solenoids under the hood so the winch would fit under the Raider body. I still had to trim the plastic winch clutch lever a tiny bit but I had no issues with that** I have a 2-inch body lift now, so there's plenty of room, but It fit before the body lift (barely**) with half-inch shims to lower the winch frame. (removed shims after body lift installed).
-almost forgot, I had to cut about 3/4 inch off the rear of the factory front tow hook to get my plate to fit. I used a sawsall patiently and it was super clean. sorry, no close up pic of that. maybe tomorrow in the light.
I'll attach a bunch of pics of it. Sorry they're at night with a flashlight, but I think they get the important info across.
PS this is an old thing, I just am getting back into my Raider and am catching up on some stuff I always meant to share.
OBA (stock AC compressor)
Re: Winch w stock bumper [Re: 89montero] #1104157 02/03/18 05:14 AM
djacidjac Offline
3 more pics
Re: Winch w stock bumper [Re: 89montero] #1104159 02/03/18 05:15 AM
djacidjac Offline
3 more more pics
Re: Winch w stock bumper [Re: 89montero] #1104160 02/03/18 05:18 AM
djacidjac Offline
last 1 pic
oh, bonus!; I used an old body mount bushing as a cushion between the hook and the fairlead so I just pull the winch in untill it snugs and all good. no rust or noise and no hook yanked against a d-ring or anything. looks tidy too. This setup could use some reinforcing on the bumper/fairlead, but, you know, I'll get right on that.
Re: Winch w stock bumper [Re: 89montero] #1104165 02/03/18 07:09 PM
rxinhed Online Kewl
Good job
Re: Winch w stock bumper [Re: 89montero] #1104168 02/05/18 04:33 AM
0778drz110 Offline
Nice work. I've had a 10K HF winch for 7 years now, still works. I haven't used it a ton, but I have had to use it and I got my $300 out of it.
Page 4 of 4 1 2 3 4
PHP: 7.2.34 Page Time: 0.037s Queries: 20 (0.014s) Memory: 2.8956 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2021-02-25 10:52:10 UTC
