Gen1 2.6L alternator upgrade
by rascott. 09/19/18 05:27 AM
WTB: Mitsubishi Gen1 seatbelt
fuel tank/ separator tanks
by rxinhed. 09/06/18 04:00 AM
1989 LWB A/T Temp Light
Echo
89 Trooper wiring question
by Resman7. 09/05/18 11:48 AM
Gen 1 & 2 Monteros for sale
by . 08/25/18 02:30 PM
0 registered members (), 119 guests, and 5 spiders.
Topics137,912
Posts1,079,635
Members14,783
6g72 SOHC - Blowing Head Gaskets - Why? #1104188
02/14/18 07:56 PM
02/14/18 07:56 PM
tdf46  Offline OP
Pierce County, WA
I have been trying to bring a 93 Montero SR back to life. Had the engine parts machined at a reputable shop a couple years ago. Blew a head gasket soon after the rebuild. Fixed that one and later it happened again. So, I have blown a head gasket twice.
During the last head gasket replacement I was careful to assure that the head bolts were NOT bottoming out before the torquing.
The heads were milled a bit by the machine shop. So, now my thinkig is that the compression is slightly higher than stock, and the stock head gaskets are not holding up.
I'm considering installing ARP studs (allbeit an expensive alternative to standard head bolts).
If anyone has other ideas about what is happening to cause this 6g72 SOHC engine to blow gaskets, I'm all ears!
Thanks for reading
Re: 6g72 SOHC - Blowing Head Gaskets - Why? [Re: tdf46] #1104194
02/15/18 03:04 AM
02/15/18 03:04 AM
rxinhed  Offline
Gerber, CA *****
Even the 4-cyl guy, me, can direct you toward the investigation. The issue could simply be false torque on the headbolts. The 3.0L (6G72) has blind pockets for the headbolts and often bottom out. Especially if the heads have been milled. you need to measure the bolt length, measure the gasket thickness, etc. There should be room left over for bolt and often isn't.
1980 Power Wagon W400
Re: 6g72 SOHC - Blowing Head Gaskets - Why? [Re: tdf46] #1104199
02/15/18 01:57 PM
02/15/18 01:57 PM
tdf46  Offline OP
Pierce County, WA
I was aware of the "bolts too long issue" and that's what I meant by my second sentense above.
However, I will once again measure to make sure the bolts are not bottoming out before th torque spec is reached. Or go to studs. If I find a bolt length issue, is the best resolution to add a second washer or do I need to grind off the bolt (hardened steel) ?
Thanks for your reply rxinhed.
Re: 6g72 SOHC - Blowing Head Gaskets - Why? [Re: tdf46] #1104202
02/16/18 01:35 AM
02/16/18 01:35 AM
rxinhed  Offline
Gerber, CA *****
I guess I'm guilty of just reacting, and I dot not even see the big "NOT"....sheesh
Page Time: 0.010s Queries: 15 (0.003s) Memory: 0.9975 MB (Peak: 1.0810 MB) Zlib disabled. Server Time: 2018-09-23 16:03:06 UTC
