NEEDED: Used Carb for 87 Raider
by Tuxedo_Ranch. 03/22/19 09:06 PM
Carb and vacuum issues
by Tuxedo_Ranch. 03/22/19 08:56 PM
Question about alternator upgrade - wiring
by GrantCee. 03/22/19 08:13 PM
New Here... Will it Fit?
by srd_raider. 03/18/19 07:00 PM
Front Shock Hoops - Weld Kit
by code33. 03/17/19 01:23 AM
DRBII for 89 Montero
by MarkG. 03/16/19 10:13 PM
GEN1 6G72 Fuel Pressure
by MarkG. 03/16/19 10:07 PM
by GrantCee. 03/18/19 10:53 PM
by srd_raider. 03/18/19 02:14 PM
99 montero power mirrors not working
by jeffmort. 03/16/19 04:54 AM
0 registered members (), 145 guests, and 5 spiders.
Topics137,989
Posts1,079,984
Members14,898
Rear transfer case seal #1104384
06/09/18 05:30 PM
06/09/18 05:30 PM
8
87Raider  Offline OP
Las Vegas NV
Hello, I can't seem to get this seal to stop leaking, I've tried a speedi-sleeve and new seal, new u- joints had the shaft balanced. It didn't leak until I pulled it to rebuild the engine, also the 4th gear is hard to come out of, not sure if it's related. Thanks for any info. Mike
Re: Rear transfer case seal [Re: 87Raider] #1104386
06/09/18 06:23 PM
06/09/18 06:23 PM
rxinhed  Offline
Gerber, CA *****
How is your output shaft runout? Any motion?
1980 Power Wagon W400
Re: Rear transfer case seal [Re: 87Raider] #1104388
06/09/18 09:41 PM
06/09/18 09:41 PM
8
87Raider  Offline OP
Las Vegas NV
What's the easiest way to check it? Do I have to pull the transfer case?
Re: Rear transfer case seal [Re: 87Raider] #1104391
06/10/18 06:08 AM
06/10/18 06:08 AM
rxinhed  Offline
Gerber, CA *****
Pull and tug on the driveshaft, see what kind of motion is there.
4th gear issue not related to the engine rebuild, but could be a sign of imminent failure.
Re: Rear transfer case seal [Re: 87Raider] #1104393
06/10/18 05:30 PM
06/10/18 05:30 PM
8
87Raider  Offline OP
Las Vegas NV
Well, there's some play in it but it's hard to tell if it's the output shaft or the yoke. Also the bolts were lose on the shifter and it always had issues with going into 2nd gear, if you pulled it towards you when shifting it kinda went into nowhere. You had to pull it straight back into 2nd. Now that's it all tightened up it seems to hang up in 4th. Trany has about 40k since rebuild.
Re: Rear transfer case seal [Re: 87Raider] #1104394
06/11/18 12:17 AM
06/11/18 12:17 AM
8
87Raider  Offline OP
Las Vegas NV
Well, I believe I found the problem, after years of oil leaking the tranny mount was like jelly! it looked good until I did the test you suggested and notice I was moving the whole tranny/transfer about an inch both ways. I believe that's what was destroying the seals. Now to order a new seal, I had a extra mount on the shelf and now it only moves about a millimeter. Thank you Sir..
Page Time: 0.010s Queries: 15 (0.004s) Memory: 1.0127 MB (Peak: 1.1133 MB) Zlib disabled. Server Time: 2019-03-23 02:28:04 UTC
