NEEDED: Used Carb for 87 Raider
by Tuxedo_Ranch. 03/22/19 09:06 PM
Carb and vacuum issues
by Tuxedo_Ranch. 03/22/19 08:56 PM
Question about alternator upgrade - wiring
by GrantCee. 03/22/19 08:13 PM
New Here... Will it Fit?
by srd_raider. 03/18/19 07:00 PM
Front Shock Hoops - Weld Kit
by code33. 03/17/19 01:23 AM
DRBII for 89 Montero
by MarkG. 03/16/19 10:13 PM
GEN1 6G72 Fuel Pressure
by MarkG. 03/16/19 10:07 PM
by GrantCee. 03/18/19 10:53 PM
by srd_raider. 03/18/19 02:14 PM
99 montero power mirrors not working
by jeffmort. 03/16/19 04:54 AM
0 registered members (), 145 guests, and 5 spiders.
Topics137,989
Posts1,079,984
Members14,898
3.0 engine swap from 5spd. to auto #1080194
03/28/16 08:45 PM
03/28/16 08:45 PM
gen1v6raider  Offline OP
Tennessee
hey ya'll,
i am in the middle of an engine swap from an 89 raider manual tranny to a 91 long wheel monty automatic. The torque converter had to be pulled up with bolts to mate with the flexplate and i believe it has pulled the shaft out of the pump and it won't go into gear. Is there a spacer on the back of the crankshaft i missed on the donor motor? It is a good half inch difference between the two. Both cranks have the same part number so what gives?? Do i need to have one made at the machine shop? Any help would be greatly appreciated.
Re: 3.0 engine swap from 5spd. to auto [Re: gen1v6raider] #1080374
04/23/16 12:06 AM
04/23/16 12:06 AM
rxinhed  Offline
Gerber, CA *****
You have a few issues here:
1. You posted in an Archive.
2. There is an adapter plate between the engine and bell housing, and they are different thicknesses for the stick and auto transmissions. However, they are not 0.5" thick.
3. It does sound like you have a problem with the snout of the trans and that could be that you have not 'screwed' the internals of the torque convertor in properly. There is an installation sequence discussed in the FSM (factory service manual) that you can find at mitsubishilinks.com...remember to drop a small token if you download anything.
Russell
Re: 3.0 engine swap from 5spd. to auto [Re: gen1v6raider] #1080386
04/23/16 09:43 PM
04/23/16 09:43 PM
rxinhed  Offline
Gerber, CA *****
I requested that the thread was moved from the Archive. So, 1 problem down.
Thanks, John. wink
1980 Power Wagon W400
Re: 3.0 engine swap from 5spd. to auto [Re: gen1v6raider] #1080411
04/27/16 01:15 AM
04/27/16 01:15 AM
PajEvo  Offline
Airdrie, Alberta, Canada *****
Just to add to what Russ said, I once did the exact same swap, from a 5 speed 2door raider to an auto LWB Montero. If you use the adapters that came with the auto, it mates up perfectly.
Re: 3.0 engine swap from 5spd. to auto [Re: gen1v6raider] #1104392
06/10/18 03:43 PM
06/10/18 03:43 PM
V
V8Fan  Offline
Santa Cruz, Bolivia
Hello,
I have a 2door Dodge Raider 1989 and would like to make a V8 engine swap. Does any body have which engine (preferable hemi) fits?. I would like to use manual transmission as well.
Page Time: 0.028s Queries: 15 (0.022s) Memory: 1.0066 MB (Peak: 1.0978 MB) Zlib disabled. Server Time: 2019-03-23 03:18:18 UTC
