OEM Mitsubishi Parts closing
by GrantCee. 10/18/18 10:53 PM
Introduction & New Raider
by Bigshankhank. 10/18/18 08:59 PM
1991 Montero RS does not stay running
by franknspeed. 10/15/18 10:58 PM
Battery light - what's it telling me?
by GrantCee. 10/13/18 08:03 PM
Timing chain maintenance?
by GrantCee. 10/13/18 07:57 PM
5.2 Swap into 88 Monty
by rxinhed. 10/13/18 03:09 AM
2001 Montero can I tune the ecu?
by TainterRacing. 10/12/18 06:58 PM
by GrantCee. 10/18/18 06:16 PM
by TainterRacing. 10/12/18 06:39 PM
by Bigshankhank. 10/11/18 04:56 PM
by GrantCee. 10/10/18 07:12 PM
by franknspeed. 10/06/18 11:38 PM
by MontyPython. 10/04/18 02:03 AM
0 registered members (), 116 guests, and 6 spiders.
Topics137,920
Posts1,079,685
Members14,828
GEN1 LWB Radio reception #1104378
06/06/18 03:02 PM
06/06/18 03:02 PM
C
chadzeilenga  Offline OP
Charlotte, NC USA
Hi All,
I'm in the process of replacing the current CD unit in my 89 LWB with an OEM Mitsubishi unit with the equalizer. Luckily the PO used an adapter harness with the unit in it and I'm not dealing with any cut wires. This current radio works ok and gets a decent signal.
I bought an OEM radio and had shipped. The seller claimed it worked etc. I installed the unit and I get no reception, it is just white noise. I removed radio and checked all connections and still nothing. I operated the radio out of the instrument panel while plugged in and it got great reception. Once I put back in there was nothing again. With the radio outside of the dash, I tried to wiggle the wires and could not re-create the issue of white noise.
So in summary, the radio only works when loosely placed on the floor and not properly installed. Can this be an issue with my installation or internal to the unit? The FSM provides no internal troubleshooting on radios with my symptoms. All connections were fully seated.
Chad Zeilenga
1989 Gen 1 Montero
Re: GEN1 LWB Radio reception [Re: chadzeilenga] #1104379
06/06/18 11:19 PM
06/06/18 11:19 PM
TOASTY  Offline
Mesa AZ, US. *****
Mine was like that too, unfortunately i don't have a fix for you. My thought was that the socket for the antenna is dead so it only works when the radio is out or you are very near a signal. I fixed it by installing a different stock radio. There are a lot of period correct radios from other Monteros and cars, I got one of the later ones with the smooth buttons. It doesn't look as 80's as the others but it works really well. I had the exact same radio you have to begin with but now i have the single din which is ok because i got a single din solid wood faceplate for the cubby which looks really nice.
1999 Montero Blizzard package
2005 Montero Limited
2015 Mirage with antifreeze Sparco wheel package
Re: GEN1 LWB Radio reception [Re: chadzeilenga] #1104382
06/07/18 03:43 AM
06/07/18 03:43 AM
C
Charlotte, NC USA
Thanks for the input. I was hoping this one could be saved, but no luck. There is supposedly one in a yard nearby I can check out and install in parking lot to check function.
You mention other period correct units. Is that only up to 1991 for the Gen1’s or also Gen2. Can you share a pic of yours?
Chad Zeilenga
1989 Gen 1 Montero
Re: GEN1 LWB Radio reception [Re: chadzeilenga] #1104403
06/12/18 05:09 AM
06/12/18 05:09 AM
C
Charlotte, NC USA
Hi Toasty,
I picked up another equalizer radio and installed in my Montero. I am having the same issues, so I believe it is a reception issue and will start checking the antenna connection to the radio. Maybe the wire is not making a good connection when the radio is fully installed.
Chad Zeilenga
1989 Gen 1 Montero
Re: GEN1 LWB Radio reception [Re: chadzeilenga] #1104407
06/14/18 03:44 AM
06/14/18 03:44 AM
TOASTY  Offline
Mesa AZ, US. *****
Let's hope so, maybe they just suck. I got mine from a base model '93, you should be able to use most any Mitsu radio from '95 or older.
Re: GEN1 LWB Radio reception [Re: chadzeilenga] #1104421
06/24/18 05:34 AM
06/24/18 05:34 AM
C
Charlotte, NC USA
I spent some time working on the radio tonight. Removed the unit. Made sure all the wires were routed well. Re-installed and made sure everything was tight. Removed antenna, cleaned the threads, reinstalled. Still getting the poor reception issue, unless I hold the antenna wire at the back of the radio with my hand. I can turn the issue on and off by doing this, I wasn't sure if there was some sort of amplifier that I'm providing etc?
Chad Zeilenga
1989 Gen 1 Montero
Re: GEN1 LWB Radio reception [Re: chadzeilenga] #1104436
06/28/18 02:33 PM
06/28/18 02:33 PM
DRTDEVL  Offline
Las Cruces, NM *****
I would open the radio's case and check the condition of the antenna connection. Probably has some cracked solder or possibly bent outward (looser) where its not making good contact anymore. Bend or solder as necessary, and reinstall.
Re: GEN1 LWB Radio reception [Re: DRTDEVL] #1104453
07/04/18 05:46 AM
07/04/18 05:46 AM
C
Charlotte, NC USA
That’s a good point drt. I’ll have to take a look when I have the radio back out.
One item I’m working to confirm is that the antenna wire is known good. Also, looking at the FSM, there appears to be a grounding configuration possibly behind the front fender. Has anyone had one off they can share a picture before I cause any damage on mine?
I was going to try and install a new antenna harness as the reception appears to be better with the wire straight.
Chad Zeilenga
1989 Gen 1 Montero
Re: GEN1 LWB Radio reception [Re: chadzeilenga] #1104514
08/12/18 06:03 AM
08/12/18 06:03 AM
C
Charlotte, NC USA
I was able to pull a full antenna assembly out of a donor in junkyard, so next step is to swap that part out and see if there is any change now that I have a different wire connecting to the radio.
Chad Zeilenga
1989 Gen 1 Montero
Page Time: 0.009s Queries: 16 (0.002s) Memory: 1.0406 MB (Peak: 1.1705 MB) Zlib disabled. Server Time: 2018-10-19 05:12:02 UTC
