1 registered members (Tuxedo_Ranch),
237
Topics138,076
Posts1,080,455
Members14,974
Most Online678 Dec 8th, 2019
fuel tank/ separator tanks
#1104559
09/03/18 09:28 PM
I'm working on getting my montero road worthy after putting in a donor motor last fall. now here's my question.
after realizing my gauge contact broke off inside the tank and the small screws will never come off under the truck I decided to pull the tank and give it a go over. turns out it was worse off than I thought. few pin holes coming through too. no problem, I'm gonna POR15 the outside and put a liner kit inside it. what I'm confused about is how necessary are the maze of little separator tanks on the top. all of the metal line up there had to be cut off (rust). since it's not a pressurized tank could I not maybe put one line to the front charcoal vent and plug the others?? any thoughts? thanks
Love the raider, hate the raider, love the raider,..... new: '88 Montero, auto, LSD 2.6L '87 Raider, 2.6L(#2), 5spd, Dual batt., Xterra roofrack......soon off to the wreckers
Re: fuel tank/ separator tanks
[Re: 87CanadianRaider]
#1104560
09/04/18 06:00 PM
I've restored the tank on a 3.0L Montero, so I don't know if this will help you much or not.
However, if there's any way to save (or replace) those tubes, do it. I had one tube outlet I let get clogged with the POR15 and the "check engine" light was on forevermore afterward.
87 Montero, bought new, by me - 88/89 intercooled Starion Turbo engine- with awesome audio. 89 LWB Montero LS - Rebuilt engine, Tunes added.  Oscar Wilde: [i]"Experience is the name so many people give to their mistakes."
[Re: dadrab]
#1104561
09/04/18 07:10 PM
yeah it's kinda late to save them now. cut two saved one. I dont think my 4cyl. carb is gonna care., the mech fuel pump will draw regardless. either way a CIL is better than leaking gas all over my driveway lol
#1104565
09/06/18 04:00 AM
I would not worry, just connect all the tubing.
1988 Mighty Max turbo 2.6 service body 1980 Power Wagon W400 Out of the parts business now, unless you visit Montero Ranch
