by rascott. 02/17/19 10:05 PM
Rebuild a Power Steering Pump
by MarkG. 02/17/19 03:55 AM
Upgrade City
by DRTDEVL. 02/16/19 03:53 AM
by ATTILA. 02/12/19 10:16 PM
Upgrade City
by tdf46. 02/01/19 09:03 PM
Buy my 1988 Montero!
by DRTDEVL. 01/30/19 09:29 PM
by Crops. 01/30/19 08:17 PM
0 registered members (), 129 guests, and 5 spiders.
Topics137,971
Posts1,079,920
Members14,882
1991 Montero RS does not stay running #1104587
10/06/18 11:38 PM
10/06/18 11:38 PM
F
franknspeed  Offline OP
Michigan
Was diagnosed as bad MAF. Finally found a used one but the same happens. Truck runs for a couple of minutes and then dies. Already has new fuel pump , coil wires and plugs. Head gasket and timing belt replaced. Heads rebuild. I’m running out of options. Almost think that it is starving for gas, but not sure fuel filter also fresh
Any suggestions?
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104588
10/07/18 10:19 AM
10/07/18 10:19 AM
cheesegrater  Offline
Franklin IN
If you think it's a fuel delivery issue, you can drizzle some gas into the carburetor when it stumbles to be sure.
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104589
10/07/18 03:08 PM
10/07/18 03:08 PM
MarkG  Offline
Scaly Mountain, NC, USA *****
Are there any codes?
02 6G74 Montero Limited
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104590
10/07/18 08:07 PM
10/07/18 08:07 PM
F
Michigan
No current codes. When it’s over 75F the O2 sensor code comes on. Now that it is cooler that doesn’t happen anymore. Been like this for over 2 years.
The engine runs fine for a couple of minutes and then starts to sputter and dies. You can hear the fuelpump running, so that should no be the issue
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104591
10/07/18 08:07 PM
10/07/18 08:07 PM
F
Michigan
Water in the gas maybe? Sea foam treatment worth trying?
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104592
10/08/18 01:47 AM
10/08/18 01:47 AM
G
GrantCee  Offline
Oregon
Are you by any chance running a K&N filter?
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104593
10/09/18 02:35 PM
10/09/18 02:35 PM
F
Michigan
Stock intake setup with stock filter.
Is it possible to mix the connections on the fuel filter and with that cause a problem?
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104594
10/09/18 06:48 PM
10/09/18 06:48 PM
G
GrantCee  Offline
Oregon
Have you replaced the injection pressure regulator?
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104603
10/12/18 03:27 PM
10/12/18 03:27 PM
F
Michigan
Not yet, I’ll try that next. Pretty soo. The whole truck is rebuilt...🙄
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104609
10/13/18 03:11 AM
10/13/18 03:11 AM
rxinhed  Offline
Gerber, CA *****
Do you have the right MAF? 89 and 90/91 are different. If the FI system (not carb, CG) is not building pressure due to a faulty regulator...could have this effect.
Lastly, what about the troubleshooting section in the FSM?
1980 Power Wagon W400
Page Time: 0.012s Queries: 17 (0.005s) Memory: 1.0597 MB (Peak: 1.1979 MB) Zlib disabled. Server Time: 2019-02-18 16:14:26 UTC
