4m40 swap into a 1990 LWB
by guzzilapd - 08/19/19 12:07 PM
Rancho, Tokico or KYB Front Shocks?
by polar - 08/19/19 11:39 AM
Hello! New member 87 Raider with questions!
by Chrystine - 08/19/19 03:54 AM
Name of 90's Montero parts catalog?
by rxinhed - 08/19/19 02:52 AM
Free Things at The Montero Ranch
by rxinhed - 08/19/19 12:49 AM
WTB - G54B Timing cover
by rxinhed - 08/14/19 03:02 AM
by oxide - 08/13/19 12:11 AM
by polar - 08/18/19 09:47 PM
Parting out a 1993 Montero SR
by sullysgarage - 08/10/19 06:59 AM
GEN I V6 Shocks Any Suggestions?
by polar - 08/09/19 01:11 AM
by polar - 08/08/19 12:59 AM
1 registered members (1 invisible), 101 guests, and 5 spiders.
Topics138,037
Posts1,080,245
Members14,945
1991 Montero RS does not stay running #1104587 10/06/18 11:38 PM
F
franknspeed Offline OP
Was diagnosed as bad MAF. Finally found a used one but the same happens. Truck runs for a couple of minutes and then dies. Already has new fuel pump , coil wires and plugs. Head gasket and timing belt replaced. Heads rebuild. I’m running out of options. Almost think that it is starving for gas, but not sure fuel filter also fresh
Any suggestions?
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104588 10/07/18 10:19 AM
cheesegrater Offline
If you think it's a fuel delivery issue, you can drizzle some gas into the carburetor when it stumbles to be sure.
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104589 10/07/18 03:08 PM
MarkG Offline
Are there any codes?
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104590 10/07/18 08:07 PM
F
No current codes. When it’s over 75F the O2 sensor code comes on. Now that it is cooler that doesn’t happen anymore. Been like this for over 2 years.
The engine runs fine for a couple of minutes and then starts to sputter and dies. You can hear the fuelpump running, so that should no be the issue
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104591 10/07/18 08:07 PM
F
Water in the gas maybe? Sea foam treatment worth trying?
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104592 10/08/18 01:47 AM
G
GrantCee Offline
Are you by any chance running a K&N filter?
1987 Montero SWB, 2.6L, 5spd
Weber conversion
2-valve head from Engine Machine Service
"4G54 FTW!"
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104593 10/09/18 02:35 PM
F
Stock intake setup with stock filter.
Is it possible to mix the connections on the fuel filter and with that cause a problem?
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104594 10/09/18 06:48 PM
G
GrantCee Offline
Have you replaced the injection pressure regulator?
Weber conversion
"4G54 FTW!"
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104603 10/12/18 03:27 PM
F
Not yet, I’ll try that next. Pretty soo. The whole truck is rebuilt...🙄
Re: 1991 Montero RS does not stay running [Re: franknspeed] #1104609 10/13/18 03:11 AM
Do you have the right MAF? 89 and 90/91 are different. If the FI system (not carb, CG) is not building pressure due to a faulty regulator...could have this effect.
Lastly, what about the troubleshooting section in the FSM?
1980 Power Wagon W400
For Sale: #277 Montero
PHP: 5.6.40 Page Time: 0.012s Queries: 16 (0.004s) Memory: 1.0063 MB (Peak: 1.1515 MB) Data Comp: Off Server Time: 2019-08-19 13:57:29 UTC
