by chadzeilenga. 01/24/19 03:24 AM
by rxinhed. 01/23/19 07:22 AM
by rxinhed. 01/23/19 07:19 AM
by rxinhed. 01/23/19 07:16 AM
by rxinhed. 01/23/19 07:14 AM
My first Raider
by rxinhed. 01/23/19 07:02 AM
by Bevoman. 01/22/19 11:22 PM
2nd Gen Front Lincoln Locker.
by ATTILA. 01/13/19 01:29 PM
by RockDoc. 01/12/19 10:31 PM
My first Raider
by Flicky8. 01/12/19 03:28 AM
by tdf46. 01/09/19 03:56 AM
0 registered members (), 139 guests, and 6 spiders.
Topics137,963
Posts1,079,883
Members14,875
New Gen 1 owner need some help #1104641
10/24/18 06:21 PM
10/24/18 06:21 PM
travish325  Offline OP
Louisville, Kay
Hello,
I just picked up a 1990 Montero and am looking for some help finding info on a few things. I came from 4runners and Land Cruisers, so I'm use to being able to find information easily; however, it is not that simple with these old Monteros.
- Can anyone point me in the direction of finding a timing belt DIY and interval?
- I have found that I should have a 28 spline 8in front diff, and 28 spline 9in rear diff... Are there drop in lockers available for each diff without having to do a full axle swap? I believe I have found an ARB for the rear, but I cant find much for the front.
- Does anyone have experience running 7in LED headlights to replace the factory sealed beams? On that note, where can I find aftermarket/JDM corner markers and tail lights?
Thanks in advance!
I plan on building this into a hunting/expedition vehicle so I will get a thread going on that soon.
-Travis
Re: New Gen 1 owner need some help [Re: travish325] #1104642
10/24/18 11:56 PM
10/24/18 11:56 PM
G
GrantCee  Offline
Oregon
Welcome!
What model do you have - 2 door, 4 door? Which engine/transmission?
As to lighting, I'm not yet sold on the LEDs available. (I should be more specific: I'm not impressed with any of the units available at decent cost. The JW Speaker 8700 are awesome, but they're also $350 each!) Then you have the issues with cold lamps and snowy/icy conditions...no thanks.
On the recommendation of Daniel Stern, I'm currently doing a swap from sealed beams to the semi-legendary Koito H4 units, complete with new wiring harness. I'll let you know how they work out.
Re: New Gen 1 owner need some help [Re: GrantCee] #1104645
10/25/18 11:29 AM
10/25/18 11:29 AM
Louisville, Kay
Originally Posted by GrantCee
Welcome!
Sorry should have added that... It is a 4 door 3.0 v6 auto.
Re: New Gen 1 owner need some help [Re: travish325] #1104646
10/25/18 03:11 PM
10/25/18 03:11 PM
Bigshankhank  Offline
Tampa Bay Area
I just did the timing belt this past weekend for my 3.0 V6 SWB Raider, same engine. The factory manual can be downloaded from mitsubishilinks.com (look in the stickies in this forum for other links) and it gives a pretty detailed description of how to replace the timing belt. Go ahead and replace the water pump because its buried in there as well and it takes a while to get in that deep so you might as well while you're in there.
1989 Dodge Raider V6
2001 Jeep Wrangler 4.0L
2008 Toyota 4-Runner SR5 4wd
Re: New Gen 1 owner need some help [Re: travish325] #1104649
10/25/18 11:04 PM
10/25/18 11:04 PM
G
GrantCee  Offline
Oregon
Well, I'll let everyone else chime in then — I've got the SWB with the 2.6l I4 and 5-speed, and would be of no help at all to you!
(I'd actually like to have a 4-door, as it would be more practical for carrying stuff, but don't need any more projects.)
Re: New Gen 1 owner need some help [Re: travish325] #1104659
10/31/18 05:20 AM
10/31/18 05:20 AM
so_ber  Offline
Oregon
I was wondering about the aftermarket tail lights and markers as well. Are they legal? Do they need wiring re-routed? There are some on Ebay I've seen. Ok ratings...
Here:
https://www.ebay.com/itm/MITSUBISHI...ts-lamp-turn-signal-blinker/282356590172
1990 Montero LS (retrofit project!)
Re: New Gen 1 owner need some help [Re: so_ber] #1104663
10/31/18 07:39 PM
10/31/18 07:39 PM
G
GrantCee  Offline
Oregon
Here:
Those are the "all the world except the US" rear lights. Since the vehicles we got have combined stop/turn signals, they require some re-wiring in order to fit those lights. I'm considering going through the trouble of doing it, because a) they look cool and b) they add a layer of safety by separating the brake and turn signals.
To the best of my knowledge, they are completely legal.
Re: New Gen 1 owner need some help [Re: GrantCee] #1104665
10/31/18 09:29 PM
10/31/18 09:29 PM
so_ber  Offline
Oregon
That'd be cool if you do! Hopefully you'll post your findings/progress as well. I might do the conversion too, sometime in the future. Are you thinking to get the ones off Ebay?
Re: New Gen 1 owner need some help [Re: travish325] #1104672
11/06/18 07:28 PM
11/06/18 07:28 PM
Louisville, Kay
Anyone have info on front and rear E/air lockers?
Re: New Gen 1 owner need some help [Re: travish325] #1104673
11/07/18 12:25 AM
11/07/18 12:25 AM
G
GrantCee  Offline
Oregon
There are no options for the 4-cyl Gen1, although many (perhaps most) of them came with limited slip rear differentials. That's pretty much it, to the best of my knowledge.
The V6 models used different differentials. I believe ARB makes air lockers for the front, and I understand the locking rear axle from the Gen2 or 2.5 models will swap in. Someone else will have to chime in on that, however, because I'm not sure about the details.
Page Time: 0.014s Queries: 16 (0.005s) Memory: 1.1031 MB (Peak: 1.2435 MB) Zlib disabled. Server Time: 2019-01-24 10:31:31 UTC
