by rxinhed - 01/27/21 03:16 AM
by B_Line - 01/21/21 04:16 PM
by polar - 01/14/21 08:40 PM
torsion bar question
Vet over his Head
by polar - 01/14/21 08:42 PM
by tcb762 - 01/12/21 11:02 PM
by code33 - 01/03/21 03:52 AM
Vet over his Head
by polar - 12/27/20 08:57 PM
0 registered members (), 89 guests, and 5 spiders.
Posts1,080,943
Page 4 of 6 1 2 3 4 5 6
Re: 4D56 into Mazda B2600i swap thread [Re: PartyTruck] #1015591 05/30/15 02:44 AM
JeffatTireBalls Offline OP
Update...
I've put about 50,000 miles on this engine now and it still runs flawless. I'd do it again in a heartbeat!
99 Montero SR
Mazda B2600i with 4D56T diesel swap http://www.4x4wire.com/forums/showflat.p...ID=#Post1240274
Re: 4D56 into Mazda B2600i swap thread [Re: JeffatTireBalls] #1102876 01/28/17 08:47 AM
Maciek Offline
Awesome, now that's worth the swap.
Re: 4D56 into Mazda B2600i swap thread [Re: JeffatTireBalls] #1104281 04/08/18 02:57 PM
7 years and I still love this truck!
99 Montero SR
Re: 4D56 into Mazda B2600i swap thread [Re: JeffatTireBalls] #1104503 08/05/18 05:08 PM
H
hambodian Offline
Nice truck. I'm just wrapping up my 4d56T swap into a 89 Ram 50. Man, seemed like swap info is very limited for these. I looking at the exhaust manifold and there isn't much space. How did you get the EGT probe in there?
96 Sportage EX. Automatic. Sold and sadly missed
4" UpYourKia lift
89 Ram 50 4x4. 4D56T swap in progress
30x9.5x15 Pirelli Scorpion M/T on Toyota steel wheels
06 VW Touareg V10 TDI.
Re: 4D56 into Mazda B2600i swap thread [Re: JeffatTireBalls] #1104716 11/27/18 01:24 PM
So I finally after all of these years installed an intercooler. This is a factory one from a Mitsubishi Pajero. The install was pretty easy, I just had to bend the two brackets that bolt to the core support a little and make a bracket for the rear to mount to the fire wall.
There is a noticeable power difference and I picked up another 5psi of boost.
99 Montero SR
Re: 4D56 into Mazda B2600i swap thread [Re: hambodian] #1104717 11/27/18 01:25 PM
I put the EGT probe in my EGR block off plate.
99 Montero SR
Re: 4D56 into Mazda B2600i swap thread [Re: JeffatTireBalls] #1104718 11/27/18 04:55 PM
I moved the stereo up to the pocket that's right under the air vents. By using a mechless stereo (no CD player) I was able to mount it without removing or modifying the duct work for those vents that's behind the panel. This makes reaching the stereo much easier and safer. I was also able to move my CB up to where the stereo was and reinstall the original pocket underneath the CB....
99 Montero SR
Re: 4D56 into Mazda B2600i swap thread [Re: JeffatTireBalls] #1104794 01/08/19 08:33 PM
Installed a snorkel for cooler fresh air to the turbo and obviously deep creek crossings that we have here in Eastern KY.
99 Montero SR
Re: 4D56 into Mazda B2600i swap thread [Re: JeffatTireBalls] #1104856 02/12/19 10:16 PM
ATTILA Offline
Wonderful truck and nice clean swap. I have that same motor in my '93 Pajero SWB, recently acquired and getting used to a real Vermont winter. So far so good. Starts like a champ and runs very well.
What did you settle on for boost pressure after installing the intercooler? I'd like to tweak my rig's settings - a little.
Thanks!
"Shut up" she explained.
Re: 4D56 into Mazda B2600i swap thread [Re: ATTILA] #1104860 02/18/19 06:28 PM
Thanks!
Thanks! I have it set to about 16psi for now.
99 Montero SR
PHP: 7.2.34 Page Time: 0.032s Queries: 16 (0.011s) Memory: 2.8940 MB (Peak: 3.1638 MB) Data Comp: Off Server Time: 2021-01-28 12:25:53 UTC
