Upgrade City
by DRTDEVL. 02/16/19 03:53 AM
by ATTILA. 02/12/19 10:16 PM
Rebuild a Power Steering Pump
by Bigshankhank. 02/12/19 12:49 AM
by rascott. 02/11/19 04:12 AM
Upgrade City
by tdf46. 02/01/19 09:03 PM
Buy my 1988 Montero!
by DRTDEVL. 01/30/19 09:29 PM
by Crops. 01/30/19 08:17 PM
0 registered members (), 116 guests, and 4 spiders.
Topics137,971
Posts1,079,918
Members14,882
Page 2 of 2 1 2
Re: Gen 1 LWB brake lights not working. [Re: Jay Ayala] #1070210
03/25/14 06:26 AM
03/25/14 06:26 AM
BottomFeeder  Offline OP
OKC, OK
Hey BottomFeeder,
May I borrow one of those hazard flashers? I would like to do a "Salvage" thread on a hazard switch.
You sure can.
Pm me
Re: Gen 1 LWB brake lights not working. [Re: BottomFeeder] #1104811
01/16/19 02:43 PM
01/16/19 02:43 PM
Bigshankhank  Offline
Tampa Bay Area
I need to resurrect this thread.
89 Raider, I was sitting in a drive through waiting for my food and decided on a lark to test the hazard switch and nothing happened. Upon leaving I noticed that I no longer had turn signals, nor brake lights. I checked all of the fuses in the little panel between the dash and drivers door, all are good. The running lights work on all four corners, and the dual filament bulbs in the rears are good as well. I then replaced the round relay below the steering wheel which I believe is the hazard/turn signal flasher. Still no improvement. There is a black rectangular relay mounted next to this, closer to the fire wall. I pulled the hazard switch out of the dash and took it apart, the solder points on the backing plate all look good, no loose wires, and the two copper plates inside the switch are in good shape and the springs are intact.
Any thoughts?
edit: Just dug a little deeper in my search and uncovered all of the information on the hazard switch. I'll run through Jay's switch rebuild and see where that leaves me and update accordingly. I didn't bother to look for this switch in the Raider at my local JY, but I am heading there this weekend.
1989 Dodge Raider V6
2001 Jeep Wrangler 4.0L
2008 Toyota 4-Runner SR5 4wd
Re: Gen 1 LWB brake lights not working. [Re: BottomFeeder] #1104812
01/17/19 03:53 PM
01/17/19 03:53 PM
Tampa Bay Area
Success. Mine required a little fettling though as part of the clear plastic arm behind the rocker was broken and missing, and one side of the housing was broken and wouldn't catch the backing plate so I had to add a shim to compress the springs and tape it back together, but upon testing I have signals again!
Backing plate and corrosion.
Slide plate.
Broken housing.
Shim.
Taped up.
Re: Gen 1 LWB brake lights not working. [Re: BottomFeeder] #1104817
01/23/19 07:14 AM
01/23/19 07:14 AM
rxinhed  Offline
Gerber, CA *****
Good job!
1980 Power Wagon W400
Page 2 of 2 1 2
Page Time: 0.010s Queries: 16 (0.004s) Memory: 1.0113 MB (Peak: 1.0988 MB) Zlib disabled. Server Time: 2019-02-16 23:27:49 UTC
