Suspension Seat for 87 Raider
by srolmeda. 05/24/19 08:53 PM
WTB - GEN1 Montero Transmount bushing
by chadzeilenga. 05/22/19 07:49 PM
by rxinhed. 05/22/19 02:39 AM
WTB 2 Door Montero
by rxinhed. 05/22/19 02:27 AM
1987, 2.6L, power steering pump bracket
by rxinhed. 05/17/19 12:50 AM
91 Montero Gas Smell
by rxinhed. 05/14/19 12:32 AM
Skid plates for 87 Raider
by rxinhed. 05/14/19 12:30 AM
WTB 2 Door Montero
by Malykaii. 05/16/19 04:35 PM
by Tuxedo_Ranch. 05/11/19 03:00 AM
by Tincan. 05/11/19 02:01 AM
Need 1989 Windshield Washer Reservoir Tank
by polar. 05/07/19 06:23 PM
0 registered members (), 148 guests, and 4 spiders.
Topics138,007
Posts1,080,090
Members14,923
Page 2 of 2 1 2
Re: 87 Gen1 Rebuild in Kansas [Re: Tuxedo_Ranch] #1104970
04/18/19 04:04 AM
04/18/19 04:04 AM
Tuxedo_Ranch  Offline OP
Hutchinson, Kansas
Well I must have caught a SERIOUS RAIDER DISEASE.
Found the only other Raider in Hutchinson and it was a lot cleaner than mine, so I bought it. I’m now the proud owner of a 1988 Raider w/ AT, rebuilt 2.6 and right at 100k miles. Gave $2,500 for it but it will make an excellent run around vehicle for my wife for when we get her 2008 ‘Burban sold.
May have to post some pics for it later.
'87 GEN1 Dodge Raider 5-speed 2.6L w/ Weber
'87 Ford Ranger STX 5-speed 2.9L V6
‘88 GEN1 Dodge Raider AT 2.6L w/ Weber (The newest addition to the family)
'95 Ford Bronco Eddy Bauer
'99 Toyota 4-Runner Limited 3" lift
WELCOME TO MY "USED" CAR LOT
Re: 87 Gen1 Rebuild in Kansas [Re: Tuxedo_Ranch] #1104985
04/28/19 02:28 AM
04/28/19 02:28 AM
Hutchinson, Kansas
Well all my front end parts came in for the 87 Raider project, so it is in the shop getting them and the OME lift kit installed.
In the mean time, I've got mama's 88 Raider to work on. It had a Weber carburetor when we bought it, but it's settings were all messed up, NO fuel pressure regulator and the "kick-down" cable was not attached (88 has an automatic tranny) and it wouldn't run over 2k RPM's or 35-40 mph.
Re: 87 Gen1 Rebuild in Kansas [Re: Tuxedo_Ranch] #1104986
04/28/19 02:33 AM
04/28/19 02:33 AM
Hutchinson, Kansas
I spent all day re-working the throttle linkage, properly connecting the "kick-down" cable, installed Holley fuel pressure regulator and changing oil.
I re-used the throttle cable cam from the stock carb. I think I may have to do a little more work to get everything working properly, the secondary's aren't opening up and I don't know why (time for more research, anyone have any idea's??).
I read a lot of posts about how to connect the "kick-down" cable and found lots of things being done to fill the gap from the throttle cam arm to the cable end, from using a piece of wire to a zip tie. I wanted to use something a little more durable and didn't know what I was going to use. Last night I woke up with the perfect solution. I went to the local farm store and purchased a few different sized chain master-links, so I would have some adjustability in length. WORKED LIKE A CHARM!!! Tranny shifts perfect now.
Re: 87 Gen1 Rebuild in Kansas [Re: Tuxedo_Ranch] #1104987
04/28/19 02:38 AM
04/28/19 02:38 AM
Hutchinson, Kansas
Fuel pressure regulator went on quick (about 15 minutes), since I already worked through the issues installing one on my 87. Noticed the fuel pressure was "bouncing" between 0-4 psi (ding ding ding ding). I think I have a bad fuel pump and the local parts store won't have one until tomorrow. Hope that fixes the issue.
Last thing for today was adding 5oz of sea foam to the oil and running it for about 20 minutes while I sprayed the carb with Sea Foam to clean out the carbon. Did the "Hot" soak and re-run. Then changed oil and filter. I'm amazed how much smoother it runs.
Think I'll take it to a tranny shop for a service after I get the new fuel pump installed.
Re: 87 Gen1 Rebuild in Kansas [Re: Tuxedo_Ranch] #1104988
04/29/19 09:07 PM
04/29/19 09:07 PM
Bigshankhank  Offline
Tampa Bay Area
Love the chain link fix, brilliant!
1989 Dodge Raider V6
2001 Jeep Wrangler 4.0L
2008 Toyota 4-Runner SR5 4wd
Re: 87 Gen1 Rebuild in Kansas [Re: Tuxedo_Ranch] #1104990
04/30/19 12:30 AM
04/30/19 12:30 AM
Hutchinson, Kansas
Thanks Hank, I thought it would be a lot more reliable than a piece of wire or a zip tie. Hopefully it will help out someone else who was struggling with the issue.
Re: 87 Gen1 Rebuild in Kansas [Re: Tuxedo_Ranch] #1105005
05/11/19 02:41 AM
05/11/19 02:41 AM
Hutchinson, Kansas
Still waiting to get my Raider out of the alignment shop, taking a while to get parts.
Mama's Raider is running great now that I got the "kick down" cable properly adjusted and the carb tuned up. I was having a problem with the fuel pressure fluctuating between 0 and 4 psi. Couldn't figure out what the problem was but expected an issue with the existing fuel pump. Come to find out, the previous owner had installed the incorrect fuel pump trying to avoid using a fuel pressure regulator (BIG MISTAKE). It had a restriction on both outlets and wouldn't feed fuel fast enough to the Weber, so the bowl was running dry during acceleration. Also had a conversation with the PO and he didn't remember plugging the coolant port in the intake manifold that was used to heat the Mikuni carb. Gonna have to pull off the Weber and conversion plates tomorrow, to tap and plug the port if it hasn't already been done.
Say Hank, did you find a rear wiper arm, I have an extra somewhere you can have if you still need it.
Re: 87 Gen1 Rebuild in Kansas [Re: Tuxedo_Ranch] #1105009
05/11/19 01:39 PM
05/11/19 01:39 PM
Tampa Bay Area
Great updates, glad to hear you figured out the Weber's problems.
Yes, I do still need a rear wiper arm, especially as it is getting in to the rainy season here in Florida. I'll shoot you a PM.
Re: 87 Gen1 Rebuild in Kansas [Re: Tuxedo_Ranch] #1105012
05/12/19 12:43 PM
05/12/19 12:43 PM
Hutchinson, Kansas
I know what you mean about rain, We've had around 9" in the last week with hail and tornadoes all over the place. All the ponds are full and country roads around my place are flooded, my boys have to go an extra 10-12 miles just to get to school.
Page 2 of 2 1 2
Page Time: 0.011s Queries: 18 (0.003s) Memory: 1.0547 MB (Peak: 1.1905 MB) Zlib disabled. Server Time: 2019-05-25 13:48:29 UTC
