by rascott - 01/23/20 03:51 AM
Twin turbo 6g72 swap
by Loganshero - 01/22/20 09:44 PM
Time to Sell Raider
Two Free Bouncy Seats Gen 1
by AK0311 - 01/20/20 04:22 PM
89 Dodge Raider for Sale
Time to Sell Raider
0 registered members (), 145 guests, and 5 spiders.
Topics138,087
Posts1,080,517
Members14,997
Why would only #2,4, and 6 get fuel? #1105136 07/19/19 01:22 AM
R
RaiderpowerV6 Offline OP
So I need some help, 89 dodge raider 3.0, I cant get my timing right, when I'm on #1 with the plug grounded. My timing mark is not in the 10 o'clock position to be around top dead center. The mark is actually in the 2-3 o'clock position. I am throwing 2 codes code 41 and 14. So TPS and injector codes. When it runs and i pull off each plug wire at the distributor, the idle only changes when I remove 2,4, and 6 wires. 1,3, and 5 does nothing, when I remove them there is no difference in idle, and the plug wire is sparking to the distributor. So I know it's getting spark on that side. Also I have a new distributor, cap, rotor, plugs, and wires. So are my injectors plugged, or fuel rail plugged up, or? I also replaced the fuel filter which had a dark mud looking liquid coming out of it, so It may have blown through the fuel filter and plugged something up.
I have also tore the front end off and made sure all timing marks were lined up. I lined up both cam dots to cam notch, and lined up pulley to 0 TDC on it's up stroke. Any input would be greatly appreciated
Re: Why would only #2,4, and 6 get fuel? [Re: RaiderpowerV6] #1105140 07/25/19 05:48 AM
K
KrzyDav Offline
The 3.0 dizzy cap conducters don't go straight thru,,, they offset. You can usually see the routing inside cap.
dave h.
Re: Why would only #2,4, and 6 get fuel? [Re: KrzyDav] #1105145 07/25/19 04:46 PM
C
chadzeilenga Offline
I'll never forget the time I was installing my distributor and just couldn't get the timing right and shortly before I reached the point of no return, I turned the cap over and discovered this. It seemed like a mean trick...haha
Chad Zeilenga
1989 Gen 1 Montero
PHP: 7.2.26 Page Time: 0.016s Queries: 15 (0.008s) Memory: 2.8313 MB (Peak: 3.1638 MB) Data Comp: Off Server Time: 2020-01-24 04:49:05 UTC
