102
guests, and 3
Topics138,182
Posts1,081,023
Members15,163
Why would only #2,4, and 6 get fuel?
#1105136
07/19/19 01:22 AM
So I need some help, 89 dodge raider 3.0, I cant get my timing right, when I'm on #1 with the plug grounded. My timing mark is not in the 10 o'clock position to be around top dead center. The mark is actually in the 2-3 o'clock position. I am throwing 2 codes code 41 and 14. So TPS and injector codes. When it runs and i pull off each plug wire at the distributor, the idle only changes when I remove 2,4, and 6 wires. 1,3, and 5 does nothing, when I remove them there is no difference in idle, and the plug wire is sparking to the distributor. So I know it's getting spark on that side. Also I have a new distributor, cap, rotor, plugs, and wires. So are my injectors plugged, or fuel rail plugged up, or? I also replaced the fuel filter which had a dark mud looking liquid coming out of it, so It may have blown through the fuel filter and plugged something up.
I have also tore the front end off and made sure all timing marks were lined up. I lined up both cam dots to cam notch, and lined up pulley to 0 TDC on it's up stroke. Any input would be greatly appreciated
Re: Why would only #2,4, and 6 get fuel?
[Re: RaiderpowerV6]
#1105140
07/25/19 05:48 AM
The 3.0 dizzy cap conducters don't go straight thru,,, they offset. You can usually see the routing inside cap.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: KrzyDav]
#1105145
07/25/19 04:46 PM
The 3.0 dizzy cap conducters don't go straight thru,,, they offset. You can usually see the routing inside cap. I'll never forget the time I was installing my distributor and just couldn't get the timing right and shortly before I reached the point of no return, I turned the cap over and discovered this. It seemed like a mean trick...haha
