by chadzeilenga - 09/23/20 06:30 PM
by B_Line - 09/21/20 04:08 PM
by nonkjo - 09/17/20 02:28 PM
by B_Line - 09/16/20 09:53 PM
1 registered members (chadzeilenga), 108 guests, and 5 spiders.
Topics138,139
Posts1,080,767
Members15,096
1990 Jeep Comanche 6cyl. Won't Start? HELP! #1105298 10/23/19 12:11 AM
P
polar Offline OP
Was running fine...then did some stick welding to the frame around/behind the passenger side door. Battery was disconnected and welder was grounded to frame.
Now turns over but will not start............replaced plug wires, ECU
Re: 1990 Jeep Comanche 6cyl. Won't Start? HELP! [Re: polar] #1105299 10/23/19 03:47 PM
4x4Wire Offline
I would go back to the battery and connections. Clean battery connections and double check/clean the ground binding between frame - chassis - engine. The ground does need a good solid bond free from rust and corrosion.
Then, there is the TDC (Top Dead Center) sensor. With the 4.0l engine, that is a common problem.
Re: 1990 Jeep Comanche 6cyl. Won't Start? HELP! [Re: polar] #1105300 10/24/19 12:33 AM
P
polar Offline OP
Thanks John.
Is TDC sensor same as the Crankshaft Position Sensor??
Re: 1990 Jeep Comanche 6cyl. Won't Start? HELP! [Re: polar] #1105301 10/25/19 03:14 PM
Mike Bondi Offline
On most engines, they are the same.....Mike
2013 Wrangler Rubicon, 2014 Jeep Cherokee Latitude, 09 Mercedes Benz ML350 4matic...Old scooter trash trying to do good, in the flat lands of Indiana
Moderated by  4x4Wire, Mike Bondi
PHP: 7.2.33 Page Time: 0.028s Queries: 15 (0.007s) Memory: 2.8369 MB (Peak: 3.1636 MB) Data Comp: Off Server Time: 2020-09-23 19:15:39 UTC
