79
guests, and 4
Posts1,081,774
1990 Jeep Comanche 6cyl. Won't Start? HELP!
#1105298
10/23/19 12:11 AM
Was running fine...then did some stick welding to the frame around/behind the passenger side door. Battery was disconnected and welder was grounded to frame.
Now turns over but will not start............replaced plug wires, ECU
Re: 1990 Jeep Comanche 6cyl. Won't Start? HELP!
[Re: polar]
#1105299
10/23/19 03:47 PM
I would go back to the battery and connections. Clean battery connections and double check/clean the ground binding between frame - chassis - engine. The ground does need a good solid bond free from rust and corrosion.
Then, there is the TDC (Top Dead Center) sensor. With the 4.0l engine, that is a common problem.
[Re: polar]
#1105300
10/24/19 12:33 AM
Thanks John.
Is TDC sensor same as the Crankshaft Position Sensor??
[Re: polar]
#1105301
10/25/19 03:14 PM
On most engines, they are the same.....Mike
2013 Wrangler Rubicon, 2014 Jeep Cherokee Latitude, 09 Mercedes Benz ML350 4matic...Old scooter trash trying to do good, in the flat lands of Indiana
PHP: 7.4.30 Page Time: 0.028s Queries: 15 (0.008s) Memory: 2.8678 MB (Peak: 3.1933 MB) Data Comp: Off Server Time: 2022-08-14 21:01:53 UTCValid HTML 5 and Valid CSS
