by TresMon - 07/12/20 06:52 PM
Hankook or Nitto?
by 4x4Wire - 07/12/20 02:16 AM
87 Gen1 Rebuild in Kansas
by polar - 06/27/20 11:11 PM
by polar - 06/17/20 09:19 PM
by - 06/14/20 05:54 PM
Hankook or Nitto?
by Jx4x4 - 06/02/20 04:14 AM
0 registered members (), 89 guests, and 6 spiders.
Topics138,123
Posts1,080,667
Members15,072
88 Raider with Jeep 2.5L & AX-15 swap #1105336 11/12/19 12:20 AM
P
Patchman Offline OP
I bought a 88 Raider last summer for my boys to learn how to drive. After a few hundred miles, the timing chain failed. After looking around for parts, I decided the Mitsubishi engine was going bye bye. I already had an extra AX-15 trans and NP231 t-case in the garage, so I figured I would just get a 2.5l and the dakota bellhousing and give it a shot.
Well, it was a lot of work, and I don't think I do this sort of thing again for a while...
Re: 88 Raider with Jeep 2.5L & AX-15 swap [Re: Patchman] #1105337 11/12/19 01:00 AM
P
Patchman Offline OP
I used a 2.5 from a 97 Wrangler with multi-port injection. That way I could avoid any security stuff in the ECU and it would fire up relatively easy.
I made some crude motor mount brackets so that I could use the original Raider mounts.
I also made a simple bracket to attach the original power steering pump and v-belt. I used the old style Delco alternator and v-belts instead of the 97 serpentine system.
I used the original radiator and the Jeep clutch fan. I got some cheap flexible metal radiator hoses due to the inlets and outlets being on the opposite sides.
Re: 88 Raider with Jeep 2.5L & AX-15 swap [Re: Patchman] #1105341 11/14/19 03:56 AM
The 2.5 is a good little engine, plenty for a Raider.
V6 Montero radiator has top hose to other side, but not sure of the bottom.
Welcome to 4x4Wire!
Re: 88 Raider with Jeep 2.5L & AX-15 swap [Re: rxinhed] #1105346 11/18/19 02:34 AM
P
Patchman Offline OP
Good to know about the V6 radiator! If I ever have to replace it I will look for one.
I wish I could find somebody nearby that could use these extra Mitsubishi parts. I hate to scrap them...
Re: 88 Raider with Jeep 2.5L & AX-15 swap [Re: Patchman] #1105348 11/18/19 04:55 PM
I'm getting ready to recycle 3 different cars & trucks, and parts from multiple part outs, because no one wants to visit the Montero Ranch for numerous free things.
Re: 88 Raider with Jeep 2.5L & AX-15 swap [Re: Patchman] #1105353 11/19/19 06:20 PM
plh Offline
What transfer case did you go with?
  • 88 Raider: 5 spd, 4.62 LSD F & R, T/L, OME Rear Springs, KYB G/A, 33/12.5/15" MTZs, PLH LOs, Justice Bumper, Dual Bouncies, 4D56T in -running soon!
  • 1992 RS M/T
  • 1993 SR
  • 2005 Montero LTD
  • Gen 1 - PARTS FOR SALE
  • http://www.tuffpans.com
Re: 88 Raider with Jeep 2.5L & AX-15 swap [Re: plh] #1105361 11/23/19 10:53 PM
P
Patchman Offline OP
The ax-15 already had a NP231 bolted on. Drivers side drop. Used an Advanced Adapters cable shifter. Works good.
PHP: 7.2.31 Page Time: 0.012s Queries: 17 (0.004s) Memory: 2.8517 MB (Peak: 3.1638 MB) Data Comp: Off Server Time: 2020-07-16 04:43:28 UTC
