96
guests, and 4
Posts1,081,743
Re: suzi the psychic
[Re: rascott]
#1105479
02/26/20 07:15 AM
got to a point of reassembly- things seem to fit. ![[Linked Image from i301.photobucket.com]](https://i301.photobucket.com/albums/nn56/rascott_2008/IMG_0237_1.jpg) still looking forward.
'94 "tracker", with some parts from suzi the psychic. other modifications made, with more to come. some intentional. suzitoo should get me fishing. kj6esv
[Re: rascott]
#1105480
02/26/20 03:33 PM
Dang, 33's!? looking good dude!
[Re: rascott]
#1105482
02/26/20 09:00 PM
Suzi looks like she's coming together nicely! Those 33's should help get you to those fishing holes a little easier. By the time you get done with her she'll be "SUPER" SUZI the wonder truck.
Keep it top side up and rolling out the progress updates,
LLT
87 GEN1 Raider 5-spd w/ Weber (HAGAR) 87 GEN1 Monty 5-spd stock (LUCKY EDDIE) 88 GEN1 Raider A/T w/ Weber (HELGA) 87 Ford Ranger STX 5-spd 2.9L V6 95 Ford Bronco Eddy Bauer 99 Toyota 4-Runner Limited 3" lift
WELCOME TO MY "USED" CAR LOT
[Re: rascott]
#1105483
02/28/20 07:22 AM
suzi the psychic is wheels down again. assembled enough to move her around a bit(after gear oil fill), so i can sort out any alignment issues and see if things still look o k. still more metal i want to glue-on under her. still eyeballin' the 33's- i'm conflicted- want to believe she could turn them. haha
[Re: rascott]
#1105484
03/01/20 02:57 AM
![[Linked Image from i301.photobucket.com]](https://i301.photobucket.com/albums/nn56/rascott_2008/IMG_0245_1.jpg) put some fluids in, made some alignment tweaks, and tried some street work. feel o k, so progress(?) will continue.....still need to beef the rear a-arm mounts, this will probably include building a new front skid. last season suzi started leaking steering fluid, and i have a new pressure hose to put on. the low pressure hose seems to be soft&swollen, so should change that too. movin' right along.
[Re: rascott]
#1105486
03/02/20 06:56 PM
managed to r&r the window and crank gear, driver's door, and made it work better. the passenger door is exhibiting similar symptoms, so i'll apply some of the same boogery to it.... there is beauty in function. the driver side mirror is too busted up to repair, so i need to find a replacement. got some tune-up stuff arriving to promote a successful smog testing. hope that works. also gonna refresh her front brakes. put steering fluid in it and tried to see where it leaks from again. guess i should replace those hoses...… mabe that'll fix it.
tagon030220 found a replacement mirror. that was easy. it's electric. mabe…..got the control switch.
[Re: rascott]
#1105500
03/11/20 05:28 AM
smog testing didn't go as i had hoped. idle HC is a bit too high, and the tech didn't like my modified header or the non CARB catalytic converter...…. gonna throw some money at her- replace the header/cat setup. decided to revamp the stowage, and have torn out 'most everything. i hope to carry less stuff, or at least organize it better. considered mounting the spare differently, played with different locations, considered not carrying one,.... finally getting some rain here. we need it! still pretending to be in "go" condition soon.
[Re: rascott]
#1105506
03/25/20 01:42 AM
Parts R Us in orland, ca has about 30 of suzi's brothers and sisters that might net some of the early model parts.
[Re: rascott]
#1105527
04/16/20 05:00 AM
i need to take some pictures. i am almost done with a mostly new exhaust- at least back to the muffler. this better work- started with a doug thorley header and a new catalytic converter. should be able to make 'er smogable(?) in couple of days. still trying some stowage changes. this corona situation makes this all more interesting. stay safe.
[Re: rascott]
#1105531
04/22/20 05:53 AM
very pleased to report that suzi the psychic has passed the smog hurdle(once again!), and cleaner than ever. now we can start getting serious. here is the doug thorley header. ![[Linked Image from i301.photobucket.com]](https://i301.photobucket.com/albums/nn56/rascott_2008/IMG_0285.jpg) watched the tech drive it and see the back-up lights don't work. mabe stopped a powersteering leak- this is a recurring problem? still looking forward.
