by TresMon - 07/12/20 06:52 PM
Hankook or Nitto?
by 4x4Wire - 07/12/20 02:16 AM
87 Gen1 Rebuild in Kansas
by polar - 06/27/20 11:11 PM
by polar - 06/17/20 09:19 PM
by - 06/14/20 05:54 PM
Hankook or Nitto?
by Jx4x4 - 06/02/20 04:14 AM
0 registered members (), 97 guests, and 5 spiders.
Topics138,123
Posts1,080,666
Members15,072
Installing an oil pressure gauge ?? #1105489 03/04/20 07:25 PM
A
Andries_VH Offline OP
So I have "base" model Gen 1 with the 3.0 V6 it does not have the 3 gauge cluster.With the engine having 230k miles on it and some lifter noise that goes away when I rev it a little. Prior to replacing the oil pump, lifters, water pump, timing belt and valve stem seals. I just want to get an idea of what my oil pressure is and if there is life left in the motor or If i should buy i rebuilt motor.
So i have no idea where to plumb in the sensor side of the oil pressure gauge. Can someone maybe help me with a photo or diagram of where to plumb it in and while you are at it. weight in on the auto zone re manufactured/refurbished engines that cost around $2k. Your advice is greatly appreciated!
Gen 1 1990 LWB Montero 3.0 v6 SOHC ineed of much love
Re: Installing an oil pressure gauge ?? [Re: Andries_VH] #1105493 03/05/20 07:44 PM
Oso Offline
not worth rebuilding the engine. the bottom end will last another 200k if well maintained. sounds servicing thee heads would be your best bet and at only half the cost.
Re: Installing an oil pressure gauge ?? [Re: Andries_VH] #1105494 03/05/20 11:46 PM
C
chadzeilenga Offline
Chad Zeilenga
1989 Gen 1 Montero
Re: Installing an oil pressure gauge ?? [Re: Andries_VH] #1105498 03/08/20 01:56 AM
MarkG Offline
The oil pressure sensor is near the oil filter.
PHP: 7.2.31 Page Time: 0.029s Queries: 15 (0.008s) Memory: 2.8390 MB (Peak: 3.1638 MB) Data Comp: Off Server Time: 2020-07-13 03:10:16 UTC
