121
Posts1,080,941
U Joint Size.
#1105812
11/19/20 04:50 PM
1990 Automatic transmission.
I can only find out the front and rear shaft are different sizes, but for the life of me cant find what size it is .. Anyone know ?
Re: U Joint Size.
[Re: Trailmonkey]
#1105813
11/24/20 02:42 PM
I mean i know my last truck had 1330 fronts and 1350 rears but this being a Mitsu i know it has to be some metric version i would think.
When i get new ones i can measure them, i see the part numbers, but as with a Spicer i know them by the size like said 1330-1350.
Do imports use the same ?
Re: U Joint Size.
[Re: Trailmonkey]
#1105814
11/25/20 02:09 AM
Your internet parts sources:
1. partsouq.com 2. rockauto.com 3. mitsubishipartswarehouse.com
The sizes are meaningless, unless you're building driveshafts. Spicer does not carry Mitsubishi u-joints any longer.
Re: U Joint Size.
[Re: Trailmonkey]
#1105815
11/25/20 01:57 PM
Yeah i can get a full Moog replacement set, it was a curiosity thing wanting to know if these are sized like or are the same as say 1330-1350....
Just to get a replacement doesnt help one learn about his truck. I know im weird.
Re: U Joint Size.
[Re: Trailmonkey]
#1105817
11/26/20 12:47 AM
The 1330 is probably closest in size, reserving the 1350 for bigger trucks. U-joint failure is not common on the Mitsus, unlike my 75 Dodge W200 that I changed from 1310 to 1350.
We are down with weird.
Re: U Joint Size.
[Re: Trailmonkey]
#1105819
11/26/20 01:25 AM
I just replaced both front brake rotors and pads, wheel bearings and seals, rebuilt the calipers. Wish i could have went ahead and pulled the CV axles out and done boots and seals while i had it on jack stands. But $$$ Did hit grease fittings.
