1 registered members (Lev_from_CA),
100
Topics138,178
Posts1,081,005
Replacement MAF unit .. Gen1
#1105908
02/07/21 03:27 PM
Has anyone had any luck with the none factory types ? I've bench tested and the flow sensor works, must be the 2 barometric sensors that are also on the unit thats giving me the trouble. Check engine light keeps coming on, not so good fuel mileage and at times a slight rough idle. Getting code for the MAF sensor from the computer. I may also try and replace the O2 sensor just to be safe.
Re: Replacement MAF unit .. Gen1
[Re: Trailmonkey]
#1105911
02/09/21 03:22 AM
Look for the wax button on the throttle body, gives weird codes and operation.
[Re: Trailmonkey]
#1105946
02/21/21 11:46 PM
I'd go for the O2 sensor first. My Gen 1 behaved oddly every now and again it felt like I was driving into a headwind or the revs would just drop. I replaced everything, temp sensor, throttle sensor, MAF, plug leads. Last thing I checked was the O2 sensor and that's what it was - could have saved a lot of time and money if I'd done it first, they don't cost much. Rgds
[Re: Trailmonkey]
#1105947
02/23/21 08:45 PM
Hey, where are you located in North Florida? I'm in Jacksonville.
[Re: Trailmonkey]
#1105948
02/24/21 01:18 AM
About 30 miles east of Tallahassee.
[Re: Trailmonkey]
#1105949
02/24/21 03:04 AM
Short notice, but a huge Mitsubishi meet this Saturday at Ace Cafe in Orlando 10-3. Florida Mitsubishi 4X4 is hoping to have 15 trucks there.
[Re: Trailmonkey]
#1105951
02/24/21 03:05 PM
A bit far for me. But thank you so much.
[Re: Trailmonkey]
#1105955
02/25/21 03:16 AM
Mudraider returns to 4x4Wire! Huzzah!
