1 registered members (Trailmonkey),
132
guests, and 4
Topics138,206
Posts1,081,279
#1105965
03/01/21 07:01 PM
Wanting to add shims to get a 0* camber. Nuts are already to the edge of the threads now. Reading others have changed out the bolt with a longer on. Cant find exactly what I need to know.
Bolt size and none threaded shaft length before threads, and what would be a good bit of extra would I need to get ? 1/4 longer or 3/8 ?
As for shims, its set at factory specs now. I want it at 0*... abouthow much would that take ? Not much I would think but then Ive never messed with this stuff.
Thanks for any advice from someone thats done this.
Re: Upper controller arm bolt size ?
[Re: Trailmonkey]
#1105968
03/03/21 09:33 PM
According to Partsouq.com, the original bolt size is 12mm diameter @ 50mm length with 1.0 threads. Increase the length accordingly.
[Re: Trailmonkey]
#1105969
03/04/21 05:33 AM
Partsouq.com has all that info ?
I thank you very much for this. I'll get shims, new nuts and bolt on the way to have on hand when I tackle the upper bushings.
[Re: Trailmonkey]
#1105971
03/05/21 05:05 AM
Indeed, has proved a valuable information source.
