74
guests, and 3
Topics138,274
Posts1,081,733
Re: Ignition Coil
[Re: Trailmonkey]
#1106079
03/13/21 03:18 PM
I dont need that Idle controller anyways, dont have the A.C. on it anymore, and I do remember it idling down till it shudders then picks back up after the initial high rev warm up. Not saying it was what started all this. I now know what did but I will definitely be disconnecting it.
And why does it have a relay for the alternator ? Like every dang thing on here has one. I know my battery (Optima) is 6 years old, but its either it or the alternator been acting up, one time its charged and worked great, next it seemed weak and barely cranked over.
Plan was to replace Battery, Alt, Starter. Now that includes Ignitor and ECU.
Re: Ignition Coil
[Re: Trailmonkey]
#1106095
03/16/21 08:51 PM
Please get me the identification numbers off the case, the big letters/numbers on the side and anything else that could help with identifying the ECU. I have several but lost track of what they came out of.
John B.
'87 Raider 2.6 Turbo Auto, Under Construction '95 Montero SR, 35x12.5/15 BFG M/T KM-2's, Rock sliders, Qtr panel chop, gas tank lift, 2" BL, Aisins, 5.29s '95 Pajero Mini '98 Montero Winter Ed. '04 Cadillac XLR '03 Kawasaki ZRX1200R '60 Ford Falcon 4Dr
Re: Ignition Coil
[Re: Trailmonkey]
#1106096
03/16/21 08:55 PM
Re: Ignition Coil
[Re: Trailmonkey]
#1106097
03/16/21 09:16 PM
Just hoping I have what he needs. They're not doing anything for me sitting on the shelf!
John B.
Re: Ignition Coil
[Re: Trailmonkey]
#1106099
03/17/21 03:41 AM
Ill look in the morning. But I dont think it has anything on the outside but a sticker, seems to be a remanufactured unit from 2015.
Re: Ignition Coil
[Re: Trailmonkey]
#1106100
03/17/21 08:43 PM
726155 is the only number on the tag other than the Remfg date.
Re: Ignition Coil
[Re: Trailmonkey]
#1106101
03/17/21 08:46 PM
E331A970A printed on the circuit board. 5271A printed on the white plastic that the plugs go but still thats under the cover.
Re: Ignition Coil
[Re: Trailmonkey]
#1106102
03/17/21 08:48 PM
Looks like that's an A1 Cardone number, Mitsu compat number for it is MD146946 (source: https://www.rockauto.com/en/moreinfo.php?pk=24808&cc=1207684 ; some great links and info on that page actually), MD175915 also comes up (former shows up as California emissions on some sites, Federal on others; latter shows up as Federal emissions).
Last edited by Lev_from_CA; 03/17/21 08:54 PM. Reason: Added second alternative part num
Re: Ignition Coil
[Re: Trailmonkey]
#1106104
03/18/21 03:06 AM
Lev you are very helpful and seem to know a whole lot about these. And dont want no cali ecu, damn thing wont ever run right again hahaha.
Re: Ignition Coil
[Re: Trailmonkey]
#1106106
03/20/21 03:39 AM
Sorry, my friend, none of mine are anywhere close to those numbers. Good luck.
John B.
