138
Topics138,276
Posts1,081,747
Re: Heater core removal,is this fellows method feasable?
[Re: dave1223]
#1018388
01/16/11 11:34 PM
Well settle in for a long job and try to go out the side first, if it doesn't work for you then take the rest of the dash off.
(aka suprathepeg, aka Sean) 89 v6 SWB truck "BLACK BEAUTY" EB valves, P&P head 30 over. 95 FZJ80. Lifted. locked and rollin on 33s (my dream machine)
[Re: Rauch_Off_Road]
#1018389
01/16/11 11:59 PM
I wouldn't be doing the work,hands shot from pinched elbow nerves and I'm not mechanical.A funny thing is the windows get somewhat fogged on early morning startup but will not fog the rest of the day with the defrost on.Had a slight leak at the clamp in the engine compartment which I tightened down a few days back but still get a little fluid on the passenger side rubber mat..sometimes green,sometimes clear looking.Could this be a build up in the heater core box?Never any anti-freeze smell.
[Re: dave1223]
#1018390
01/19/11 06:19 AM
It's a job that take some time and patience, but no big skills or special tools. A beginner could do it. Just have a sheet of cardboard handy to organize your hardware Below are some pics from when I rewired my whole truck in preparation for an engine swap. All that blue tape is labels for the different connectors on the wiring harness. It was a great project and lots of fun. -- Matt
'89 4runner SR5, 3.0, auto (fun) '93 xtra cab, dlx,3.0, 5spd (work truck)
[Re: dave1223]
#1018391
01/19/11 07:22 AM
Seems to me it might be the valve; if you lay under the truck and look straight up the firewall on the pax side, I think you'll see it.
Floor would be wet if the core.
Tip for whoever gets to be the lucky person; pull the seat, esp if you're big.
[Re: kewlynx]
#1018392
01/19/11 01:44 PM
The floor does get that little drip onto the passenger side rubber mat..just above that floor vent.Always have plenty of heat.
[Re: dave1223]
#1018393
01/19/11 01:51 PM
[Re: dave1223]
#1018394
01/29/11 10:14 AM
On an 84-88 truck or 4Runner it takes about four hours to change the heater core. Ive replaced the heater cores on two 86 4Runners, the first heater core i did took a little over five hours, but the second one only took about four hours because i knew were everything was and what had to come a part. The complete dash does have to be removed, but its not as hard as it looks, it more time consuming than anything else.
1986 Toyota 4Runner.
Solid Axle Swap, 5'' Lift, 37'' MTR`s, Duel Cases, Detroit Locker Rear, ARB High Pinion Front, 4.88 Gears, Cross Over Steering, Trail Gear Sliders, Addicted Off Road Front Bumper.
[Re: dave1223]
#1106108
03/21/21 04:51 PM
Good to see this forum still up and running. I've been putting off this heater core job for a few years with my 87 parked for a while now. Probably hit it sometime this spring. I moved to a 2002 Tacoma several years ago, but miss the 87 a bit. Different feel in those old 80s trucks. Mine's slow and beat up, but I like that just about everything in it is mechanical.
Hope all are doing well.
msg - '87 xtracab
[Re: dave1223]
#1106109
03/21/21 09:42 PM
Yeah, the old Toys were a remarkable machine, very dependable, capable and easy to repair.
Welcome back. The forums do have a lot of great information.
