77
guests, and 2
Topics138,272
Posts1,081,729
Re: OG folks chime in!
[Re: PHIL_]
#1106090
03/15/21 02:12 PM
I haven't said hello on this post, but I've been making plenty of new threads. So there's that! Hello!
[Re: Mudraider]
#1106091
03/15/21 03:11 PM
Still here, haven't logged in ages. Kind of just lurked, mostly because my threads are always picture heavy and it's just not the same without pics. Most of the old threads have broken picture links because of Montypics and photobucket. I guess I'll try Imgur, anyway good to see you dudes still posting up. I try to keep in touch with most of you outside of 4x4wire and FB so you already know what i've been up to. ![[Linked Image from i.imgur.com]](https://i.imgur.com/D0XfbTs.jpg)
[Re: PHIL_]
#1106092
03/15/21 03:35 PM
I read someone had seen ^^ mawl-crawling recently.
[Re: rxinhed]
#1106093
03/15/21 05:11 PM
Probably, It's my daily driver and my only functional vehicle so it has to crawl all of the things including the mall.
[Re: PA_JERO]
#1106098
03/17/21 12:11 AM
Pajero- sure thing. Just gotta sell these two boats first, I’d take the 96 and a pile of cash if you want to trade. They’re amazing off-road. 😂
[Re: PHIL_]
#1106110
03/22/21 04:38 PM
Guys, not sure if this is the place for this note, As I have been spending major time making wire harness changes in my Pajero build I have discovered major errors in the 92-95 FSM chapters covering wiring mostly concentrated in the Meters & Instrument section. I can cover this in detail if desired but dang is this getting frustrating, most all because my T case has no provision for a speedo cable I needed to change to the post 94 instruments.
Cheers, Charlie If It ain't broke, Modify it! 87 Montero turbo Converted back in Spring1989 95 Montero SR 3.8 DOHC Only one? 93 Pajero 3 door 6G75 Mivec with paddle shifted 5 speed Then a Gen2 SR with full coil independent suspension.
[Re: PHIL_]
#1106113
03/22/21 11:41 PM
Still around. Same truck... driven most days. Wheeled infrequently.
[Re: OldColt]
#1106115
03/23/21 02:55 PM
Guys, not sure if this is the place for this note, As I have been spending major time making wire harness changes in my Pajero build I have discovered major errors in the 92-95 FSM chapters covering wiring mostly concentrated in the Meters & Instrument section. I can cover this in detail if desired but dang is this getting frustrating, most all because my T case has no provision for a speedo cable I needed to change to the post 94 instruments. Could you get an electronic to cable interface from Dakota? I had looked into this for installing a JK NP241OR into a Gen 1, basically it takes signal from the VSS and you calibrate the module to spin the cable the correct RPM.
[Re: TOASTY]
#1106117
03/23/21 04:37 PM
Interesting approach I had not considered. Not sure what is needed to mate to furrin cables and at that price I would have bought another Gen 2 Xcase to swap out the Gen 3 one.
[Re: OldColt]
#1106148
03/31/21 06:03 PM
Back. I have missed this place. I pretty much left before F book because of kids and work. I need to get my Montero back to good running status.
Can I have my blue arrow icon back?
