Smoking winch
Power steering pump leak.
replace master cylinder
Ignition Coil
Smoking winch
Gen 1 starting issue
by Oso - 04/01/21 05:28 AM
0 registered members (), 228 guests, and 5 spiders.
Topics138,201
Posts1,081,246
Page 5 of 5 1 2 3 4 5
Re: Ignition Coil [Re: Trailmonkey] #1106107 03/20/21 04:18 PM
Trailmonkey Offline OP
Getting a ReMan from the parts store.
If it still wont fire It still could be the distributor or Ignitor.
Need to know what to do with the idle control unit.. just unplug it ?
Really dont need that anyway as the whole AC unit has been removed.
Disabled Driver.
Re: Ignition Coil [Re: Trailmonkey] #1106111 03/22/21 06:33 PM
L
Lev_from_CA Offline
Yep, just unplug the IAC valve. Yours seems to be a six-pin stepper unit, so to do a simple bench test you can check the resistance of the two coils inside. Here's how you'd do that for a 97 Montero Sport 3.0, the resistance values given and pin orientation is probably the same for your unit: https://workshop-manuals.com/mitsub...component_tests_and_general_diagnostics/
Some theory of operation and general expected values are in MegaSquirt's manual (interspersed with MS-relevant info): http://www.megamanual.com/ms2/IAC.htm
To fully test it, you'd need to drive the stepper motor and compare to expected values, but that's out of my knowledge. Maybe someone on here knows how to set up a jig?
PS: common failure mode for misbehaving/seized IAC valves is clogging of actuator with oil (e.g. from failed/malfunctioning PCV valve), so removing it and giving it a good cleaning may be helpful. Also, the IAC valve works downstream of the coolant temp sensor. While you're climbing around the engine bay checking sensors, you may want to check that one as well.
Last edited by Lev_from_CA; 03/22/21 06:44 PM. Reason: Example manual was a sporty monty, not SWB
Re: Ignition Coil [Re: Lev_from_CA] #1106112 03/22/21 07:38 PM
L
Lev_from_CA Offline
Your coolant temp sensor should be the standard Negative Temperature Coefficient thermistor type (resistance across single terminal and base varies with temperature; lower temp yields higher resistance). Looks like the part number is MD091056 and was used for about 20 years, from 1987 to 2007 (and is generally a simple, very reliable part). Here's how the sensor is supposed to be tested from the 2001 Pajero WSM, section 54A, pg 32 (same sensor as yours):
[Linked Image from i.imgur.com]
If you could find a resistance-temperature table for that part, you could test it without removal by heating the coolant and checking for correct resistance output.
PS: If you have rust issues, it could be that the connection with the base of the temp sensor has high resistance due to excessive rust. Taking it out, cleaning and sanding flat the mating surfaces may help.
Re: Ignition Coil [Re: Trailmonkey] #1106114 03/23/21 12:00 AM
Awesome, thank you Lev.
Disabled Driver.
Re: Ignition Coil [Re: Trailmonkey] #1106126 03/26/21 05:04 PM
JohnnyBfromPeoria Offline
Lev is a great addition around here!
John B.
'95 Pajero Mini
'98 Montero Winter Ed.
'04 Cadillac XLR
'03 Kawasaki ZRX1200R
'60 Ford Falcon 4Dr
Re: Ignition Coil [Re: JohnnyBfromPeoria] #1106130 03/27/21 12:34 AM
John B.
Very knowledgeable and helpful.
Disabled Driver.
Re: Ignition Coil [Re: Trailmonkey] #1106191 04/06/21 06:18 PM
Finally, put in the new Ignition Control unit (Ignitor) and she fired right up.
Disabled Driver.
PHP: 7.2.34 Page Time: 0.034s Queries: 16 (0.012s) Memory: 2.8746 MB (Peak: 3.1634 MB) Data Comp: Off Server Time: 2021-04-12 21:14:34 UTC
