143
guests, and 4
Topics138,201
Posts1,081,246
replace master cylinder
#1106192
04/07/21 05:29 AM
I want to remove the windshield washer reservoir to make room to work on the brake master cylinder on our '90 Gen I. It looks like the washer reservoir should just lift off the bracket but it doesn't move and I don't want to break the 31-year old plastic reservoir. Is there something else holding the reservoir or should it just lift up off the bracket?
90 LWB RS: 3 L/mt, JBaker springs, bushings, swaybars. KYB shocks tweaked, 134k mi, original owner. 97 LWB SR: SOLD Sep. 2014 131,006 mi: running boards removed, BFG 31x10.5 AT/KO tires, Air locker, AirLifts, KYB shocks, Cibie fogs, 3rd owner.
Re: replace master cylinder
[Re: nvmonty]
#1106193
04/07/21 11:49 AM
It should lift up. Might want to dribble a little dish soap down where the metal bracket slides in and rock the reservoir a bit to break the friction.
Cheers, Charlie If It ain't broke, Modify it! 87 Montero turbo Converted back in Spring1989 95 Montero SR 3.8 DOHC Only one? 93 Pajero 3 door 6G75 Mivec with paddle shifted 5 speed Then a Gen2 SR with full coil independent suspension.
[Re: nvmonty]
#1106194
04/07/21 05:30 PM
Thanks OldColt! That's what I thought but I did not want to force it....
[Re: nvmonty]
#1106195
04/08/21 03:21 AM
Turns out there are two detents at the bottom so if one pulls straight out on the bottom and then lifting it slides up. Takes some effort at the old plastic is not as flexible. But it is surprisingly tough for a vehicle made in 1989!
