the cold start shuffle got me
Topics138,274
Posts1,081,733
Are All 2.6's interchangeable? #1106319 06/08/21 07:03 AM
S
Spduffee Offline OP
Hi All,
I found a 2.6l turbo from a Starion, I guess. Will it bolt on to the Raider's automatic transmission? Or is it going to lead me down a rabbit hole?
Are the turbo 2.6's more trouble than they're worth or do they hold up well?
Thanks for any feedback
Shawn
"It idles rough in neutral" "We won't be in neutral" "Oorah"
Re: Are All 2.6's interchangeable? [Re: Spduffee] #1106323 06/09/21 05:14 AM
So many rabbit holes to go down. Some guys have good luck with the G54T. My Max, with the entire Starion conversion, was a rolling project when I purchased it.
The expression "Dollars for Donuts" from Crocodile Dundee fits here. If you really, really want to turbo your Raider, you are far ahead to get the truck 4g64 (2.4L) block, add the car 4g63T head and go forth on your merry way to hundreds of HP.
Read through the sticky post, The Turbo Bible, at the top of the feed. ALL your questions are there, though pics may be missing.
Russell
Re: Are All 2.6's interchangeable? [Re: Spduffee] #1106326 06/09/21 06:44 AM
S
Spduffee Offline OP
Thank you for pointing me to that sticky
Wow, two minutes into it and I'm a big fan of what I have.
I have spent a lot of time studying variations and trying stuff on my Jeeps, some good some bad. I think I'll just leave this one stock and enjoy it as is.
Re: Are All 2.6's interchangeable? [Re: Spduffee] #1106344 06/19/21 11:04 AM
OldColt Offline
To me the turbo swap is the best thing that can be done to a 4cyl Gen 1, I swapped mine back in winter of 1988, these shots taken spring of '89.
[Linked Image from i.imgur.com]
I find an essentially stock engine the best way to go. The transmission benefits from a V6 torque converter to utilize the low end torque of the turbo engine.
Cheers, Charlie
If It ain't broke, Modify it!
PHP: 7.4.29 Page Time: 0.028s Queries: 15 (0.009s) Memory: 2.8721 MB (Peak: 3.1929 MB) Data Comp: Off Server Time: 2022-05-26 01:07:39 UTC
