looking for donut gasket
by motero - 10/07/21 06:58 PM
by motero - 10/07/21 06:44 PM
Meetings and things
by motero - 10/07/21 05:52 PM
Rear defroster timer removal.
by Trailmonkey - 10/06/21 05:17 PM
by polar - 09/26/21 04:39 PM
by polar - 09/24/21 08:45 PM
1989 Montero AT to MT swap
0 registered members (), 110 guests, and 4 spiders.
Topics138,243
Posts1,081,555
Members15,209
‘89 Monty SWB - 1100 idle at start, -500 eventual #1105885 01/04/21 03:14 PM
BrooklynOpus Offline OP
Hey Gang,
I’m new to the site, and still learning how to navigate it. Have a couple of issues that I’m sure have been addressed at some point in here, but due to time constraints thought I would throw it out on the table again here.
1989 Montero SWB
Pretty original. Gold paint.
Solid daily driver.
Issue 1 trying to resolve:
Upon start up for the day, after warm up and getting to operating temp, the idle is high at 1100. After driving for a while, or after a 200m trip let’s say, it will idle at 500 or less, and stall once put under load.
Issue 2 trying to resolve:
Tranny is leaking. Yet to crawl underneath, but any typical leak info would be great to steer me. Also, getting into park suddenly isn’t smooth.
Issue 3 trying to resolve:
Upon start up, a bit of smoke. But immediately clears and none for rest of day. Today, started up on a steep hill. Blew smoke consistently while warming, did not thin out and stop. Not the usual clearing of the throat.
Thanks in advance for any insights!
Eric
1989 Monty 3.0 AT
1989 Raider 3.0 MT
Re: ‘89 Monty SWB - 1100 idle at start, -500 eventual [Re: BrooklynOpus] #1105886 01/04/21 03:46 PM
Update:
Pulled it out onto a flat street surface, ran for about ten minutes, and smoking stopped.
But any ideas are appreciated.
I’m guessing oil from head thru a loose valve.
But any ideas.
Thanks!
Eric
1989 Monty 3.0 AT
1989 Raider 3.0 MT
Re: ‘89 Monty SWB - 1100 idle at start, -500 eventual [Re: BrooklynOpus] #1105887 01/04/21 03:51 PM
C
chadzeilenga Offline
Hi Eric,
Welcome to the site. There is a lot of good info on here. I daily my 89 LWB. I'll take a stab at your issues:
1. Likely a dirty IACV. They are part of the Throttle Body and can be removed and cleaned. Is the idle bouncing at all?
2. Could be a pan gasket or seal. Mine leaks and I have changed the pan gasket. It's likely a seal that I haven't gotten to replacing. Be sure to be adding SPIII fluid. There are a few options other than dealer for this.
3. Likely bad valve seals, it's common on these. Some live with it and keep an eye on oil level, but they can be changed with the heads on the engine using the rope method (feed a bunch of rope into the cylinder and then compress it with piston to hold valve up when doing the seal)
Be sure to read through the archives.
Re: ‘89 Monty SWB - 1100 idle at start, -500 eventual [Re: BrooklynOpus] #1106495 09/28/21 08:05 PM
I never said thank you, Chad. Sorry about that.
Appreciate your reply.
Since then, the truck became one of those "Well, since I'm here I might as well do that. And that. And that..."
So, did a full top end seal and gasket replace, water pump, belts, etc.
Due to the inevitable detours of life, I'm happy to say I finally started it up yesterday.
Troubleshooting continues, but if that ain't the sweetest moment after tearing something apart, I don't know what is.
Number 6 isn't firing, so have to tear it down a bit again and see whats what. Narrowed it down to the injector as a possibility.
They look original. My gut told me to replace when all was exposed, but oh well. Learnin...sometimes the hard way.
This is DIY...This is the Way...
1989 Monty 3.0 AT
1989 Raider 3.0 MT
PHP: 7.2.34 Page Time: 0.025s Queries: 15 (0.009s) Memory: 2.8396 MB (Peak: 3.1637 MB) Data Comp: Off Server Time: 2021-10-21 11:57:28 UTC
