From my understanding, the Ford 9" 28 spline is the same as the Monty 28 spline rear. So technically a Ford mini spool or possibly lunch box locker would work ?
My main concern that I have yet to find an answer to, is the cross shaft dia. For has a 3/4" shaft. Is that the same as the Monty ?
And if this is all true why can't I find any info on anyone doing this.
One would truly have to look into this but if I recall the overall dimensions of the unit and ring gear mounting are not easily compatible. Look around for a MM rear LSD, I have not looked in a few years but there were some on Car part. Once you do the plate restacking they grip quite well.
Cheers, Charlie If It ain't broke, Modify it! 87 Montero turbo Converted back in Spring1989 95 Montero SR 3.8 DOHC Only one? 93 Pajero 3 door 6G75 Mivec with paddle shifted 5 speed Then a Gen2 SR with full coil independent suspension.
I was not talking about the whole diff unit, just replacing the insides with a mini spool or possibly a Trak Lok lunch box type locker. VS just welding it shut, I'd rather not do on the smaller 9 inch 28 spline unit. Now if I had the bigger 9.5 inch 31 spline I'd just weld the sucker.
But I've seen Dana 44s welded with 31s and had no issues with limited street use. Montero 9 inch 28 spline from what I'm told-read and heard is as strong or stronger than a 44.
I was talking about the differential unit which one bolts the ring gear to. Not the whole drop out. If you had a 9.5" why not just add a compressor for the air locker?
