Gen 1 tranmission fluid
by MarkG - 08/10/22 04:39 PM
LED Headlights
The End is Near
by ybakos - 08/11/22 06:00 PM
LED Headlights
The End is Near
Posts1,081,774
power steering pump frozen in place #1106636 03/11/22 07:00 AM
nvmonty Offline OP
In the process of replacing the three engine belts on my '90 3.0 L Monty, I cannot release the tension on the power steering pump belt. I loosened the two 14mm bolts on the tension bar on the front and the 14 mm bolts on the bracket on the back but the pump will not move to release the tension on the belt. Even took out the bolt on the bracket on the back and tried priying on the pump body and it will not move. Had to cut the belt in order to remove it to replace the main alternator belt behind the power steering belt.
Any suggestions as to what might be holding the pump? So far I've resisted the temptation to whack it with a heavy hammer......
90 LWB RS: 3 L/mt, JBaker springs, bushings, swaybars. KYB shocks tweaked, 134k mi, original owner.
97 LWB SR: SOLD Sep. 2014 131,006 mi: running boards removed, BFG 31x10.5 AT/KO tires, Air locker, AirLifts, KYB shocks, Cibie fogs, 3rd owner.
Re: power steering pump frozen in place [Re: nvmonty] #1106639 03/12/22 06:09 AM
MarkG Offline
The gen 1 Service Manual is available online.... Look at www.mitsubishilinks.com
On some of the pulleys, one must loosen the center bolt on the pulley. This allows the pulley to slide to release the tension on the belt.
Re: power steering pump frozen in place [Re: nvmonty] #1106640 03/13/22 06:00 AM
nvmonty Offline OP
Problem solved. I had missed one of the bolts that needed to be loosened.
PHP: 7.4.30 Page Time: 0.026s Queries: 15 (0.009s) Memory: 2.8613 MB (Peak: 3.1931 MB) Data Comp: Off Server Time: 2022-08-16 04:56:17 UTC
