LED Headlights
The End is Near
LED Headlights
The End is Near
0 registered members (), 66 guests, and 4 spiders.
Topics138,278
Posts1,081,771
Page 3 of 3 1 2 3
Re: The Part Number Thread - New and Improved !! 4/22/05 [Re: fourwd1] #27418 02/01/07 02:27 AM
1987 Toyota 4-Runner
Front caliper rebuild kit- Toyota part #04479-30031
This is an updated part number for the 4 piston caliper with two different sized pistons. The smaller piston seals are not available in the aftermarket (33.93). This kit includes all 8 piston bore seals, boots, wire retainers and bleeder caps. Pistons are available at Napa, Car Quest and O'Reillys much cheaper and work fine.
Kit cost is $40 w/tax.
Sarge
Re: The Part Number Thread - New and Improved !! 4/22/05 [Re: fourwd1] #27419 03/30/07 10:38 AM
D
dieseldog Offline
Thought you guys might find this helpfull:
TOYOTA HILUX GEAR DRIVE TRANSFER CASE 21-SPLINE (RF1A)
QTY: PART NO: DESCRIPTION: I.D. NO: ALT ID NO: SIZES:
1 90363-35009VP BEARING, INPUT SHAFT, FRONT 6307N 6307ZNR
1 90364-19006VP BEARING, INPUT SHAFT, REAR, NEEDLE 19 X 31 X 23.6
1 90364-45002 BEARING, OUTPUT SHAFT, FRONT, NEEDLE 45 X 51 X 30.6
1 90363-40007 BEARING, OUTPUT SHAFT, FRONT 6308N 6308NR
2 90364-35001VP BEARING, OUTPUT SHAFT, REAR, NEEDLE KT354216 35 X 42 X 16.6
1 90363-28002 BEARING, OUTPUT SHAFT, REAR 63/28 28 X 68 X 18
3 90360-06004 BALL, OUTPUT SHAFT SB1/4 1/4"
1 33481-22010 GEAR, SPEEDOMETER, OUTPUT SHAFT
1 33482-39045 GEAR, SPEEDOMETER DRIVE, NYLON
2 90201-20005 WASHER, FLANGE
2 90179-20001 NUT, FLANGE
1 90363-32006VP BEARING, COUNTER SHAFT, FRONT 83A400 63/32NR 32 X 75 X 20
1 90369-45001VP BEARING, COUNTER SHAFT, REAR, NEEDLE 45 X 55 X 20
1 90365-38001 BEARING, IDLER SHAFT, FRONT 038RUSS1
1 90363-30012VP BEARING, IDLER SHAFT, REAR HR6306NX2 6306ZNR
1 90363-30014 BEARING, FRONT DRIVE GEAR, FRONT 6307N 6307ZNR
1 90369-45001VP BEARING, FRONT DRIVE GEAR, REAR, NEEDLE 45 X 55 X 20
1 90311-32009 SEAL, OIL, ADAPTER 32 X 52 X 11
1 90312-48001 SEAL, OIL, INNER 48 X 62 X 6
1 90311-38140VP SEAL, OIL, REAR FLANGE 38 X 58 X 11
1 90311-38016 SEAL, OIL, FRONT FLANGE 38 X 58 X 11
1 90303-38010 SEAL, FELT, FRONT FLANGE
1 33145-30010 RETAINER, FRONT FLANGE SEAL
1 36146-35021 GASKET, ADAPTER TO T-CASE
1 36143-35010 GASKET, REDUCTION TO FRONT HOUSING
1 36141-35010 GASKET, FRONT TO REAR HOUSING
1 36145-35010 GASKET, EXTENSION HOUSING
1 36153-35010 GASKET, FRONT RETAINER HOUSING
1 84222-35020 SWITCH, 4X4 DETECTION
2 90341-18006 PLUG, FILLER / DRAIN
1 90341-18057 PLUG, DRAIN, MAGNETIC
1 36304-35H20 HOUSING, T-CASE LEVER + GASKET
1 36360-35031 LEVER, T-CASE + BOOT
1 90521-49003 RING, SNAP
1 36303-3503001 KNOB, T-CASE LEVER
10 90119-10128 BOLT, L = 47mm
2 90119-10245 BOLT, L = 49mm
7 90119-10066 BOLT, L = 37mm
4 90119-10130 BOLT, L = 112mm
Wild About Wheeling!
Re: The Part Number Thread - New and Improved !! 4/22/05 [Re: fourwd1] #27420 06/25/07 09:45 PM
Myota Offline
Anybody know what the p/n is for the backing plate on the rear axle of a '87 22TRE, 5-speed? AND....would this be the same part for all the 4 & 6 cylinder models, '86-89?
Thanks,
Chris
'88 EFI Xtracab, 32 x 11.50 Buckshots, AZ bed, Turbo drivetrain.
Re: The Part Number Thread - New and Improved !! 4/22/05 [Re: Myota] #27421 04/28/08 06:19 PM
grandeyota Offline
This is the Toyota Part number for the bearing and dust cover that gets pressed on the side shaft of a non-ADD IFS front diff.
Bearing: 90369-36009
Dust cover: 41336-28010
Bearing circled, dust cover not pictured
Fur clog in the sausage grinder
Re: The Part Number Thread - New and Improved !! 4/22/05 [Re: grandeyota] #27422 06/01/08 03:31 PM
P
philly Offline
just got
83520-35030 oil pressure sender
but on my paperwork it says 35031 gage assy oil pr.
i thought i was gona get the wrong part. but it all worked out. 55 bucks!!! rip off!
Re: The Part Number Thread - New and Improved !! 4/22/05 [Re: philly] #27423 08/29/08 03:28 AM
cam01 Offline
Speedometer cable, 88 4runner V6, 5 speed.
83710-89165
Re: The P/ N Thread - New and Improved !! 4/22/05 [Re: cam01] #27424 09/15/08 11:41 PM
P
philly Offline
84-88 bed part numbers. if you cannot make out the number please ask.
Re: The P/ N Thread - New and Improved !! 4/22/05 [Re: philly] #27425 01/20/10 05:45 AM
Adam F Offline
I cant make out a single one
97 4R, stock, daily driver
Re: The P/ N Thread - New and Improved !! 4/22/05 [Re: Adam F] #27426 03/26/10 09:48 PM
Myota Offline
Neither can I.
I need the LH front lower side panel (19-22) for my XtraCab bed.
Page 3 of 3 1 2 3
PHP: 7.4.30 Page Time: 0.027s Queries: 16 (0.010s) Memory: 2.9182 MB (Peak: 3.1934 MB) Data Comp: Off Server Time: 2022-08-10 13:42:25 UTC
