64
guests, and 3
Posts1,081,774
Re: The Part Number Thread - New and Improved !! 4/22/05
[Re: fourwd1]
#27418
02/01/07 02:27 AM
1987 Toyota 4-Runner Front caliper rebuild kit- Toyota part #04479-30031 This is an updated part number for the 4 piston caliper with two different sized pistons. The smaller piston seals are not available in the aftermarket (33.93). This kit includes all 8 piston bore seals, boots, wire retainers and bleeder caps. Pistons are available at Napa, Car Quest and O'Reillys much cheaper and work fine. Kit cost is $40 w/tax. Sarge
[Re: fourwd1]
#27419
03/30/07 10:38 AM
Thought you guys might find this helpfull:
TOYOTA HILUX GEAR DRIVE TRANSFER CASE 21-SPLINE (RF1A) QTY: PART NO: DESCRIPTION: I.D. NO: ALT ID NO: SIZES: 1 90363-35009VP BEARING, INPUT SHAFT, FRONT 6307N 6307ZNR 1 90364-19006VP BEARING, INPUT SHAFT, REAR, NEEDLE 19 X 31 X 23.6 1 90364-45002 BEARING, OUTPUT SHAFT, FRONT, NEEDLE 45 X 51 X 30.6 1 90363-40007 BEARING, OUTPUT SHAFT, FRONT 6308N 6308NR 2 90364-35001VP BEARING, OUTPUT SHAFT, REAR, NEEDLE KT354216 35 X 42 X 16.6 1 90363-28002 BEARING, OUTPUT SHAFT, REAR 63/28 28 X 68 X 18 3 90360-06004 BALL, OUTPUT SHAFT SB1/4 1/4" 1 33481-22010 GEAR, SPEEDOMETER, OUTPUT SHAFT 1 33482-39045 GEAR, SPEEDOMETER DRIVE, NYLON 2 90201-20005 WASHER, FLANGE 2 90179-20001 NUT, FLANGE 1 90363-32006VP BEARING, COUNTER SHAFT, FRONT 83A400 63/32NR 32 X 75 X 20 1 90369-45001VP BEARING, COUNTER SHAFT, REAR, NEEDLE 45 X 55 X 20 1 90365-38001 BEARING, IDLER SHAFT, FRONT 038RUSS1 1 90363-30012VP BEARING, IDLER SHAFT, REAR HR6306NX2 6306ZNR 1 90363-30014 BEARING, FRONT DRIVE GEAR, FRONT 6307N 6307ZNR 1 90369-45001VP BEARING, FRONT DRIVE GEAR, REAR, NEEDLE 45 X 55 X 20 1 90311-32009 SEAL, OIL, ADAPTER 32 X 52 X 11 1 90312-48001 SEAL, OIL, INNER 48 X 62 X 6 1 90311-38140VP SEAL, OIL, REAR FLANGE 38 X 58 X 11 1 90311-38016 SEAL, OIL, FRONT FLANGE 38 X 58 X 11 1 90303-38010 SEAL, FELT, FRONT FLANGE 1 33145-30010 RETAINER, FRONT FLANGE SEAL 1 36146-35021 GASKET, ADAPTER TO T-CASE 1 36143-35010 GASKET, REDUCTION TO FRONT HOUSING 1 36141-35010 GASKET, FRONT TO REAR HOUSING 1 36145-35010 GASKET, EXTENSION HOUSING 1 36153-35010 GASKET, FRONT RETAINER HOUSING 1 84222-35020 SWITCH, 4X4 DETECTION 2 90341-18006 PLUG, FILLER / DRAIN 1 90341-18057 PLUG, DRAIN, MAGNETIC 1 36304-35H20 HOUSING, T-CASE LEVER + GASKET 1 36360-35031 LEVER, T-CASE + BOOT 1 90521-49003 RING, SNAP 1 36303-3503001 KNOB, T-CASE LEVER 10 90119-10128 BOLT, L = 47mm 2 90119-10245 BOLT, L = 49mm 7 90119-10066 BOLT, L = 37mm 4 90119-10130 BOLT, L = 112mm
Wild About Wheeling!
[Re: fourwd1]
#27420
06/25/07 09:45 PM
Anybody know what the p/n is for the backing plate on the rear axle of a '87 22TRE, 5-speed? AND....would this be the same part for all the 4 & 6 cylinder models, '86-89?
Thanks,
Chris
'88 EFI Xtracab, 32 x 11.50 Buckshots, AZ bed, Turbo drivetrain.
[Re: Myota]
#27421
04/28/08 06:19 PM
This is the Toyota Part number for the bearing and dust cover that gets pressed on the side shaft of a non-ADD IFS front diff. Bearing: 90369-36009 Dust cover: 41336-28010 Bearing circled, dust cover not pictured
Fur clog in the sausage grinder
[Re: grandeyota]
#27422
06/01/08 03:31 PM
just got 83520-35030 oil pressure sender
but on my paperwork it says 35031 gage assy oil pr.
i thought i was gona get the wrong part. but it all worked out. 55 bucks!!! rip off!
[Re: philly]
#27423
08/29/08 03:28 AM
Speedometer cable, 88 4runner V6, 5 speed.
83710-89165
Re: The P/ N Thread - New and Improved !! 4/22/05
[Re: cam01]
#27424
09/15/08 11:41 PM
84-88 bed part numbers. if you cannot make out the number please ask. ![[Linked Image]](http://i241.photobucket.com/albums/ff216/akaphilly/epc/toyotabedpartnumber.jpg)
[Re: philly]
#27425
01/20/10 05:45 AM
I cant make out a single one
[Re: Adam F]
#27426
03/26/10 09:48 PM
Neither can I. I need the LH front lower side panel (19-22) for my XtraCab bed.
