looking for donut gasket
by motero - 10/07/21 06:58 PM
by motero - 10/07/21 06:44 PM
Meetings and things
by motero - 10/07/21 05:52 PM
Rear defroster timer removal.
by Trailmonkey - 10/06/21 05:17 PM
by polar - 09/26/21 04:39 PM
by polar - 09/24/21 08:45 PM
1989 Montero AT to MT swap
1 registered members (OldColt), 98 guests, and 3 spiders.
Topics138,243
Posts1,081,555
Members15,209
question on sas front hanger, anyone have pics of theres #388999 01/28/04 04:59 AM
E
Eric Upchurch Offline OP
today i pulled the bumper off the new RS to start taking some looks and measurements for the toyota axle that will soon be going under it. my plan all along was to just buy a front hanger from allpro or sky-manufacturing, but my question is if i do that will it be pushed out far enough? does anyone with a sas on a first gen have pics of how they mounted there front hanger? i'm planning on reverse shackle with either toyota rear springs or waggys.
Thanks
New rig: 89 trooper RS toyota axles with 5.29s, 35x15.5x15 swamper SXs
my Pics: http://community.webshots.com/album/124372714fTyMKI
Wrire up:http://personal.ecu.edu/emu0416/
Re: question on sas front hanger, anyone have pics of theres [Re: Eric Upchurch] #389000 01/28/04 02:28 PM
RobG Offline
Eric, if you're planning on welding the allpro hanger right up under the frame rails, then no, it probably won't move you as far forward as you would like. You'll either have to extend the frame rails or design your own custom hanger like many of us have done that move the spring eye way out in front.
orignal version of my hanger bar
version 2 (current running version)
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 38x13 TSLs, spooled D60 front, 14bff rear locked by detriot, high steer w/ hydro, dual Isuzu tcases.
Re: question on sas front hanger, anyone have pics of theres [Re: Eric Upchurch] #389001 01/28/04 08:10 PM
randii Offline
I have some similar/related bumper and front mount pictures online from the late 90's when I did UZI's front axle swap:
http://www.4x4wire.com/isuzu/randii/gifs/uzi_susp/
Those are the easiest ones to get to, but there are many similar threads out there available for search.
I searched on "solid axle swap" and also "SAS" and came up with some good old discussions. Here are a few of the threads that result:
Linky 1
Linky 2
Linky 3
Feel free to ask specific questions and I'll try to pitch in where I can, as will the rest of the SAS community, I bet...
Hope that helps,
Randii
Randy Burleson
4x4Wire Managing Editor Emeritus
Mongrel Isuzu Amigo
Re: question on sas front hanger, anyone have pics of theres [Re: randii] #389002 01/28/04 08:36 PM
E
Thanks for the pics guys.
Randi, did you make the double steering arm? thats the kind of steering set up i was wanting to do but wasn't sure if i should buy the double arm from all pro or have a machine shop make it. also are you running the ford TRE in the pitman arm?
Back to the hanger, randi your hanger looked pretty simple, just welded extentions under the frame. are you still running that set up? ok one more question <img src="/forums/images/graemlins/baby.gif" alt="" /> did you mount your shackle on that random piece of metal that hangs down from the frame, or is that a different piece that you welded on?
Thanks again for the help <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: question on sas front hanger, anyone have pics of theres [Re: Eric Upchurch] #389003 01/28/04 08:51 PM
randii Offline
I did not make the double steering arm myself... I don't trust my welding skills to that. I contracted it done to my specs.
There's a steerig thread around here that I'll try to dig up that details some of the issues of using mass-produced arms with the shorty Isuzu pitman arm... in a nutshell, I elected to use the Isuzu pitman stock and have a custom-length double-arm built. The other choices are to have a custom pitman built to work with an easily available steering arm, or to go ahead and mismatch a stock Isuzu pitman to an easily available steering arm and cope with the resultant issues.
I initially ran a spherical-rod end (SRE )at both ends of my drag link, but was unhappy with the longevity of that solution, so I dug through a few chassis fixture books and crossreferenced the various dimensions to find a stock tie rod end (TRE) that would work with the stock Isuzu pitman arm hole and taper. That bore fruit in the '72 Ford stock TRE that many folks have used with good success since then. I'm kinda proud of that, since many people told me that it couldn't be done. (I respond to that sort of challenge with almost as much joy as when someone says "that SHOULDN'T be done!)
I'm still running the original frame extensions/spring hangars that are shown in those pictures... they are 2.5" OD (2" ID) square receiver stock, that I also use to support my removable front winch. In the rear, I fabbed two solid blocks of steel and had them bored to match the OD of the shackle bushings I wanted to use, and then tacked them to the frame (as noted above, for safety-critical welds, I'll align and tack components in place, but I'll pay someone else for the peace of mind inherent in GREAT welds).
Randii
Re: question on sas front hanger, anyone have pics of theres [Re: Eric Upchurch] #389004 01/29/04 01:16 AM
Curtis Johnson Offline
Eric, I have a bare Trooper frame. Well, almost,the main part of the body comes off this week end. If it'll help I'll send you some pictures of what's up there to build on with all the sheet metal out of the way. May help help you get a better idea of the overall picture.
CJ
Re: question on sas front hanger, anyone have pics of theres [Re: Eric Upchurch] #389005 01/29/04 01:25 AM
paulevans76 Offline
are you trying to keep the stock wheelbase? why not build a frame extension like matt's RS? also, theres a thread somewhere on pirate in the toy section that shows how to do a homemade crossover setup.
88 Troop - Posing yard art
Re: question on sas front hanger, anyone have pics of theres [Re: paulevans76] #389006 01/29/04 02:46 AM
E
Curtis, that would be great if you could post some pics of how you make your hanger. are you extending the frame or just making the hanger stick out a little further.
Paul, i'm not really trying to keep the stock wheel base, but i'm not looking to extend it out to far. its mainly for simplicity to be able to just weld a prefabbed hanger on and go from there. i would like to have the axle pushed about maybe 5in forward. i'm planning on using yota rear springs which are offset so that should move it forward a few inchs with just that. i'll probably move the rear axle back about an inch as well, hopefully going from a 90in wheel base to around 95-97.
Re: question on sas front hanger, anyone have pics of theres [Re: Eric Upchurch] #389007 01/29/04 03:01 AM
we just got the front hanger done on the 87, come check it out next time you're up here. i've got all the correct steel on hand to make another hanger, toss me some cash for whatever steel you need and we can make one. got a drill press now too, so spring holes are a breeze. ours is 2x4 directly off the front frame crossmember, 3x3 box with one side cut off for the actual spring pockets, and will have 3/8" plating from the hanger to the frame/crossmember and bracing up to the stock bumper mounts as well. we're running stock dodge rear shackles, so we'll be able to switch the shackles front to rear at will if we want a different setup, pinion angle, whatever... 3 holes are drilled in the spring mounts and the shackle mount (like RobG's) so we will have quite a bit of adjustment for shackle angle, moving the axle foward/backward, and even different length springs (within reason).
Re: question on sas front hanger, anyone have pics of theres #389008 01/29/04 05:22 AM
E
Thanks ivan, that would be great if you don't mind making another. I got cash and the <img src="/forums/images/graemlins/cheers.gif" alt="" /> let me know whens a good time for you and i'll come to raleigh. i'll try to pick up that tranny you need as well, I should be going to the junkyard this week to get my axles.
what all you got left to do on yalls old trooper, just the front axle?
PHP: 7.2.34 Page Time: 0.032s Queries: 16 (0.010s) Memory: 2.9007 MB (Peak: 3.1638 MB) Data Comp: Off Server Time: 2021-10-19 14:19:57 UTC
